![]() | Home > Maintenance & Mods (L322) > Wiper Blades |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Whole wiper,
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
+1. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
+1 the thud has arrived |
The thud came back intermittently on ours on the motorway a few days ago... an it only had the Bosch 808's fited a few weeks ago. |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Me too. New Bosch blades in Jan. Thud, albeit not as bad as on originals, has returned. Is there a quality issue with new Bosch blades or is eBay the problem? Or is it the whole arm that is wearing? 2012 5.0L S/C
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35656 ![]() ![]() |
cant remember who it was but they suggested squeezing the 6 pivot joints together to get rid of any play..
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
The thud also comes from the wiper blades not being in the correct plane North/South... undo the nut on the wiper arm and you will see an aluminium holder under the arm which allows the arm to tip forward and back... To stop the thud! Simples |
do you mean this bit Craig..i tried this on my td6 and just couldnt get rid of the thud, probably unlucky getting the right setting..
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Which one for the rear chaps? Discovery 4 HSE
2 for a quid in the pound/99p shops ...18 inch ones Adam.. |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
are they 808s for a 2003
quote RRUK - Which one for the rear?
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 ![]() ![]() ![]() |
I might of already mentioned this but I was surprised when I replaced my wipers with the Bosch 808 that I still had the annoying thud.
i think because the wiper itself is so heavy the 'working' bits like the pivots and clips because loose and cause the thudding.. |
