![]() | Home > Technical (L322) > L322 gone crazy!? ...water ingress playing havoc! |
Boat.Buoy Member Since: 10 Jan 2014 Location: Bournemouth Posts: 70 ![]() ![]() |
This looks really helpful when trying to isolate which module is at fault;
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Matt, the boot seal can be a bit tricky so do take your time so as to get a good fitment/seal |
Thanks for the thought Craig, any suggestions where to start or best way to attack it?
Start on the sides where its easy to see what your doing then when you have got the hang of what your doing/how much pressure to put on the seal etc, then work your way around... |
All sorted, fitted the new boot seal, hopefully that'll keep the water out! Now just to fix the electrical issues...
yodaboy Member Since: 20 Feb 2014 Location: Teesside Posts: 3 ![]() ![]() ![]() |
Have you tried reading the OBDI to see what that says or whether it might point to a fault? |
Hi Yodaboy, Yes, I have RSW All Comms and have tried reading it. Normally it works just fine and I've been able to carry out all tasks (calibrating EAS etc). While this fault is present some functions work properl, others not at all. When connecting to the BCU I get the TX and RX lights flashing but the Error box in the bottom right hand corner lights up red, only when I try and connect to the BCU related functions. I can't display live data for suspension heights, but I can for steering angle sensor.
Anytime you disconnect the battery the "air Suspension Inactive" message will be displayed when you turn the ignition on for the first time after reconnection.
Nicedayforit, my apologies, I always forget to include something when I come in from the cold workshop...yes I did clear the EAS inactive my calibrating the steering angle sensor, I have to do this soo often at the moment its become second nature!? When I do this the extra lights go out, as does the EAS message, but it comes back after about 30 seconds.
Replaced the boot seal as suggested above, even after the rain we've had over the last few days the spare wheel well is bone dry!
