Home > Technical (L322) > Xenons - sticky/flicky ? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
Driving home tonight on country road I hit the full beam - nothing, then a flicker, then full beam. Had to drop to dipped for oncoming car, then back to full beam, flicker flicker flicker flicker flicker flicker flicker and on it went til it finally stayed on, dipped beam again then back to full and all was well. Headlights not used for three days prior. Both headlights doing it, at the same time.
19th Feb 2014 8:26pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35426 |
try the mains when the engine is off but the ignition is on, you'll be able to hear them sticking [or not]
19th Feb 2014 8:32pm |
I will, but I always had dipped beam, so it was as if the "eyelids" on the xenons were flicking up and down from duipped to full beam of their own accord, not quite getting set ? .
19th Feb 2014 11:07pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Often the switch (ind stalk) starts to break down |
19th Feb 2014 11:16pm |
Ah, thanks CTC .
20th Feb 2014 12:59am |
