Home > Technical (L322) > Supercharged Coolant pump |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Dave, fill in your car profile pal or you will be asked constant questions about age and model etc etc when posting questions on here... |
17th Feb 2014 9:48am |
Av_dave Member Since: 31 Dec 2012 Location: Stourbridge West Midlands Posts: 109 |
Good point it does make life easier I suppose. Just filled it in. The difference between theory and reality is that in theory it will work. |
17th Feb 2014 10:14am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
http://www.fullfatrr.com/forum/topic22717.html
17th Feb 2014 11:24am |
That's great thanks I will check my vin this morning.
18th Feb 2014 8:39am |
Glynn Member Since: 20 Sep 2013 Location: Lancs Posts: 64 |
But how would you know if all the issues "have" been dealt with ?. |
18th Feb 2014 8:50am |
Yep as suspected my vin falls within the affected models. Will get a new pump ordered and the pins swapped to be on safe side.
18th Feb 2014 8:51am |
in most cases just repinning the connector to the correct orientation will sort out the issue
18th Feb 2014 3:51pm |
Thanks for that will report back as soon as it's done. The difference between theory and reality is that in theory it will work. |
19th Feb 2014 9:37am |
Just an update. I've replaced my aux coolant for a genuine Bosch one. The wiring was also the wrong way round on mine as per technical bulletin. It was a pretty straight forward job and only took around an hour.
23rd Mar 2014 7:53am |
