Home > Maintenance & Mods (L322) > Air suspension - link with water? |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
On a ten year old RR you have to budget for new struts no matter how well maintained the car is. These are wear items. ----------
14th Feb 2014 9:37pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8620 |
Could be water in the height sensors, or one of the plastic sensor links got damaged.
14th Feb 2014 9:47pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
As above, water and sensors underneath are a possible problem although mine have been OK off roading and wading on Salisbury Plain and should be able to put up with a drenching.
15th Feb 2014 10:58am |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1254 |
I've seen / read / been told before that on Range Rovers you shouldn't jet wash the the suspension/ wheels as it can affect the sensors. |
15th Feb 2014 11:06am |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 |
Many thanks guys, really appreciated. Looks like it is potentially not a deal breaker then and each component not too bad to replace anyway.
15th Feb 2014 1:39pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
I don't think anyone will tell you it's ok, just in case it's not when you take it on a journey. The codes need to be read. Ian |
15th Feb 2014 1:49pm |
Not a deal breaker but a bargaining point.
15th Feb 2014 3:54pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
16th Feb 2014 7:42am |
Thanks again guys, this really helps.
16th Feb 2014 8:07am |
I thought you were on here but couldn't remember. Thanks for the kit, not fitted yet as mine is holding up but getting slow, certainly impressed with the factory bits supplied |
16th Feb 2014 8:39am |
Ah, the smilie makes more sense to the newbie now 4.2 Supercharged Vogue SE |
16th Feb 2014 8:41am |
As long as it's not down on it's bump stops then personally I wouldn't have an issue driving it. If it is disabled then the pump won't be working so any air lost won't be replaced. You just need to keep an eye on it and if it sinks then don't risk it. |
16th Feb 2014 8:43am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
to find out what IS the problem, you only need a diagnostic tool, which if you are serious about running one of these cars properly, should be a compulsory purchase anyway. you can pick one up easily for around £300 just search the forum here for tips -very all encompassing and very DIY and nothing to worry about etc. They are easy to use, in conjunction with a typical laptop -preferably one with a serial port, or with a USB to serial port adapter. I have the RSW diag cable, and its very good. on odd occasions, say about 3 times in a year, I have had the suspension warning come on, and it latches. so without the tool I could not 'release it' however, within 10 mins, I was up and running again. this can be kept in the car with an old (low value) laptop, just in case you are a little doubtful etc. ie long journey.
16th Feb 2014 9:30am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Get the owner to get it sorted before the sale, otherwise you are just potentially buying trouble, unless you can get a good £500 off the SP and you are prepared to take on the trouble. .
16th Feb 2014 12:07pm |
