Home > Technical (L322) > Misfiring, Shutting Down, Losing Power - V8 Vogue
vento
Hi guys,
Got an 03 4.4L V8 Vogue, was running perfectly fine until about a month ago, start losing power on a dual carriageway, went into limp mode. Started it again, running fine. Last 2 days, it's started misfiring a lot, lost all power on a road, turned ignition, starter motor ran but didn't start. Called AA, techy thought it was the Mass Air Fuel Sensor, he unplugged the wire in the engine bay, managed to get it home. Now it either doesn't start at all or starts for 1-2 seconds then cuts out.
We're either thinking MAF or Fuel Pump? Any ideas, what else could it be?
Getting a diagnostic tomorrow, see what happens Confused
Post #242041 11th Feb 2014 8:10pm
JAYBOY
Hello
You might want to introduce yourself to the forum before posting as it helps to get everyone on side.
Theres a thread to do so. Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #242056 11th Feb 2014 8:49pm
vento
Will do mate, thanks.
Post #242280 12th Feb 2014 5:33pm
vento
Garage done a diagnostic, no errors Confused
It was firing up yesterday but as soon as you touch the throttle, engine would cut out.
Today it's just cranking but not firing at all.
They think it's the Crankshaft Sensor (hopefully).
Post #242683 14th Feb 2014 4:23pm
Throttle pedel lost its memory? Sounds daft but happens to 4.4's... Thumbs Up
Post #242724 14th Feb 2014 7:57pm
vento
Craig, would that actually stop the car from firing up? It's now cranking but engine isn't firing up.
Post #242773 15th Feb 2014 12:38am
Yes it can do sir Bow down
Post #242774 15th Feb 2014 12:40am
vento
Thanks Craig, I'll look into that. I'm thinking it could possibly be the fuel pump aswell?
Post #242775 15th Feb 2014 1:01am
fisha
If the MAF was unplugged and it got you home then I'd still be considering the MAF as the problem. It's failure can result in exactly the symptoms you describe. It happened to me.
Is there an engine management light showing?
Do you have a simple obd2 code reader. Even the most basic ones will be able to show what the error code is to give you a starter for 10.
I put a thread up on here about MAF a long time ago and the problems I was having at the time. If he MAF reads wrong, then it gets confused and alters the fuel levels incorrectly to the point that it's runs too rich or lean and can't start /run anymore.
Long story short ... If yr going to replace the MAF, Get a genuine one from land rover .... Nothing else, only genuine.
Just replacing a MAF will not reset the error light automatically, that will need cleared too. V8 or else ...
Post #242789 15th Feb 2014 9:14am
