![]() | Home > Technical (L322) > Misfiring, Shutting Down, Losing Power - V8 Vogue |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Hello
vento Member Since: 11 Feb 2014 Location: U.K Posts: 5 ![]() |
Will do mate, thanks. |
Garage done a diagnostic, no errors |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Throttle pedel lost its memory? Sounds daft but happens to 4.4's... |
Craig, would that actually stop the car from firing up? It's now cranking but engine isn't firing up. |
Yes it can do sir |
Thanks Craig, I'll look into that. I'm thinking it could possibly be the fuel pump aswell? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1456 ![]() ![]() |
If the MAF was unplugged and it got you home then I'd still be considering the MAF as the problem. It's failure can result in exactly the symptoms you describe. It happened to me.
