Home > In Car Electronics (L322) > Sat Nav Upgrade
coasterburner
United Kingdom 2004 Range Rover Vogue Td6 Oslo Blue
Sat Nav Upgrade
Apologies if you've all seen this question before . On forum advice I sent my faulty mk3 sat nav back to the seller . I looked around Google and Ebay and the part no. YIB000080 was the one to go for to upgrade the 2004 unit . I bought a new one , but the fittings are completely different . Please help me hang on to what remains of my sanity .Is there an adaptor required ? Thanks , Ian .
Post #237987 29th Jan 2014 3:08pm
mjdronfield
These cars only ever had the BMW mk3 sat nav as standard. The upgrade unit is a BMW mk4 unit, and as it was never fitted to a land rover will not be a land rover part / part number.
The unit will look exactly like your old one but with DVD on the front.
Have a look on eBay for BMW mk4 sat nav.
Will prob be from an x5 or 5 series of about 2004 to 2006 vintage......
We'll worth the upgrade. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #238006 29th Jan 2014 5:12pm
mjdronfield
Something like this
http://www.ebay.co.uk/itm/bmw-e46-M3-MK4-D...3cdaf684a6
http://www.ebay.co.uk/itm/BMW-mk4-dvd-sat-...4acebb5072
You may need to change the startup screen from a BMW one to a land rover one. Plenty of info on the net about that and newer nav disks are also on the bay.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #238017 29th Jan 2014 5:56pm
If it doesn't fit you have the wrong one - the MKIV is a direct plug in replacement - as per Mr Dronfield. Smile
Post #238018 29th Jan 2014 5:57pm
marcoos_1
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Can I ask a stupid question, but what are the benefits of changing? What makes the Mk4 better than the RR unit?
Post #242069 11th Feb 2014 9:20pm
the mk4 is dvd based as opposed to the OE nav which is cd ..
Post #242082 11th Feb 2014 9:58pm
The MK IV is horrible, but it does work.
The MK III is almost totally useless. It's like some atari video game from the 80's. The maps are also over 10 years old.
Post #242109 11th Feb 2014 11:42pm
johnboyairey
I did the upgrade from mk3 to mk4 and it works great. but I am stuck with the bmw logo. mine was from a mini I believe. I tried to burn a RR splashscreen but it sent it a bit haywire, and blue screened it for a while. I tried a couple of different burns, but managed to get it working again. but still on the bmw logo. its a good nav, for its neatness and ease of use. though I need the name of road as not currently doing a 7 digit postcode. is there a better way of getting said RR splashscreen, and 7 digit postcode? anyone got a spare upgrade disc? I have looke dall round forums. and its currently on the latest software, (from memory) I think I need to 'back version', and then 'up version'. but im at a loss....
ps. I used matt stevensons RR page for the splash....
thanks.
Post #242111 12th Feb 2014 12:37am
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
I did matts splash screen , everything was fine Thumbs Up
Post #242580 13th Feb 2014 10:27pm
Andy
I burnt Matts software and it's fine. However, for some reason I can't turn off speed camera alerts anymore and the scale has changed in that the 75 yards option isn't there anymore.
Post #242649 14th Feb 2014 12:43pm
isnt it that you have to change the language to french fist and then you can switch off the speedcams..i'm probably wrong here though ....
Post #242652 14th Feb 2014 12:51pm
Andy
I'll try that.
When I had the facility to turn it off, the language did use to change to French. I had a play around in the Navcoder settings and changed all 3 languages to GB to try and get round this. Since then, the on/off in the config menu has gone.
Post #242653 14th Feb 2014 12:53pm
ah, you broke it then Laughing
Post #242655 14th Feb 2014 12:58pm
Andy
Possibly!
Post #242660 14th Feb 2014 1:22pm
