Home > Technical (L322) > do you find your heater to hot |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35392 |
mine is on its lowest setting of 16 degrees and the inside gets to hot , and when i put it on max and its like a sauna..strange we cant have more flexibility in the temperature control instead of starting at 16 degrees.... |
12th Feb 2014 2:11pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
I like it like a sauna. I wish it went higher than 28. |
12th Feb 2014 2:25pm |
I trust you have the centre vents on COOL(io) ? Also if you AC needs a recharge the temp will be hotter than indicated on dial. |
12th Feb 2014 2:27pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Is that with the AC on? If yes, perhaps you need to take that outfit off?
12th Feb 2014 2:31pm |
AC always on in Automatic mode and you should always be in Automatic mode
12th Feb 2014 2:33pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Inside air temperature sensor could be insulated with a layer of dirt. |
12th Feb 2014 2:36pm |
ok, centre vents are on cool and shut,
12th Feb 2014 2:37pm |
I would open the centre vents as the cool air compensates for the hot blown below and on the screen. |
12th Feb 2014 2:42pm |
You did not say if the AC is fully charged and cold? |
12th Feb 2014 2:43pm |
i assume its charged fully as it worked perfect least year, but when its off or on i get the same temperature at 16 .. |
12th Feb 2014 2:46pm |
That's my point if the AC is discharged you may get a hotter temp than desired. Funny but true in two recent RR that had discharged AC the temp was (much) hotter than indicated on dial.
12th Feb 2014 2:50pm |
If the air comes out very cold its working otherwise you will just get slightly cool air. |
12th Feb 2014 2:53pm |
i've had the a/c on all the time in this wet weather Gary, it helps a great deal in keeping the condensation off the windows... |
12th Feb 2014 2:54pm |
It really is (very) good policy to simply leave it on Auto all the time. Two lights on the control knob. Cost of extra MPG is minuscule. |
12th Feb 2014 2:57pm |
