Home > Technical (L322) > do you find your heater to hot
mine is on its lowest setting of 16 degrees and the inside gets to hot , and when i put it on max and its like a sauna..strange we cant have more flexibility in the temperature control instead of starting at 16 degrees....
Post #242205 12th Feb 2014 2:11pm
I like it like a sauna. I wish it went higher than 28.
Post #242214 12th Feb 2014 2:25pm
Re: do you find your heater to hot
I trust you have the centre vents on COOL(io) ?
Also if you AC needs a recharge the temp will be hotter than indicated on dial.
Post #242215 12th Feb 2014 2:27pm
T24RES
Is that with the AC on? If yes, perhaps you need to take that outfit off?
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Ian
Post #242218 12th Feb 2014 2:31pm
AC always on in Automatic mode and you should always be in Automatic mode Whistle
I agree get out of the GIMP suit Stan Laughing
Post #242220 12th Feb 2014 2:33pm
Inside air temperature sensor could be insulated with a layer of dirt.
Post #242222 12th Feb 2014 2:36pm
ok, centre vents are on cool and shut,
same with or without a/c on,
my GIMP suit is pink...
inside sensor will be examined Thumbs Up
just remembered, when going sharply around corners i get a slight blow of cold air..[no puns please Laughing ]
Post #242223 12th Feb 2014 2:37pm
I would open the centre vents as the cool air compensates for the hot blown below and on the screen.
Post #242227 12th Feb 2014 2:42pm
You did not say if the AC is fully charged and cold?
Post #242229 12th Feb 2014 2:43pm
i assume its charged fully as it worked perfect least year, but when its off or on i get the same temperature at 16 ..
Post #242230 12th Feb 2014 2:46pm
That's my point if the AC is discharged you may get a hotter temp than desired. Funny but true in two recent RR that had discharged AC the temp was (much) hotter than indicated on dial.
I hope you not running the SC with AC off to save a few pennies Stan as we all know it should be on 100% of the time as its conditioning/drying the air not simply cooling it. Remember those ECU's..... Whistle
Last edited by Gazellio @ Prestige Cars on 12th Feb 2014 2:53pm. Edited 1 time in total
Post #242231 12th Feb 2014 2:50pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Is there a way of checking the AC on FF's? On my old cruiser there was an eye glass in the system to see the level but on FF's there nothing. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #242233 12th Feb 2014 2:51pm
If the air comes out very cold its working otherwise you will just get slightly cool air.
Post #242236 12th Feb 2014 2:53pm
i've had the a/c on all the time in this wet weather Gary, it helps a great deal in keeping the condensation off the windows...
Post #242238 12th Feb 2014 2:54pm
It really is (very) good policy to simply leave it on Auto all the time. Two lights on the control knob. Cost of extra MPG is minuscule.
Post #242242 12th Feb 2014 2:57pm
