Home > Maintenance & Mods (L322) > Power Supply - Midtronic PSC-500 or Equivalent?
blueRR2006
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
Hello,
I'm looking at getting a power supply so that I can use to make changes to the CCF functions on my RR. LR as well as the instructions in the IIDTool .pdf suggest that a Midtronic PSC-500 or the equivalent be use. I'm looking more into the equivalent at a much lower price, would anyone have any suggestions?
Thanks
blueRR2006 2006 Range Rover HSE 4.4L Jag Engine/ Buckingham Blue
Post #241812 10th Feb 2014 10:16pm
Ctec get good writ ups on here and Lidl even sold something similar for about £12 in the UK , I think the important thing is to be a multi stage charger with microprocessor control . 2008 MY Supercharged
Post #241844 11th Feb 2014 1:39am
blueRR2006
ok, then I'll Bing/Google/ixquick search for a multi stage charger with microprocessor control.
Thanks Thumbs Up
Post #241846 11th Feb 2014 3:24am
CTEK MXS 5/7/10 should do the job for you without any problems.
The 5 is on its limits with the FF but its the one i use it just takes a little longer if the battery is totally dead but for IID/Faultmate/Autologic work with the engine off it should be cool Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #241894 11th Feb 2014 10:57am
Martin
Site Admin
For reprogramming/reflashing work you need something with a high current output. Guys over on DISCO3 use the CTEK MXS25 for this. The smaller ones don't have the current capacity to supply the vehicle when programming.
Post #241898 11th Feb 2014 11:02am
25amp charging power is a bit overkill for a car thats not running, but better safe than sorry i guess.
If your playing with multiple systems and powering your laptop from the car for the updates then i can maybe see why its needed as the longest update is Nav on the move and that can take an hour on a vehicle draing about 5-10amps at a tie could kill the smaller battery and charger on a D3/4/rrs. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #241916 11th Feb 2014 11:44am
Martin
Site Admin
Add up the current consumption of every ECU that's turned on when the ignition is on and you'll soon be drawing more than that supplied by the small charger.
There is a reason LR mandate a 50A supply Wink
Post #241918 11th Feb 2014 11:51am
Guess we are all stuffed then as 50amp chargers are just booster pack rated ones Very Happy
Maybe some jump leads onto a second battery and a normal charger would do the trick Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #241919 11th Feb 2014 11:57am
blueRR2006
Found a PM3-75 on ebay. I know 75 Amps is an overkill, but for the price and peace of mind.
http://www.ebay.com/itm/PM3-75-110-120-VOL...1123870500
Post #242121 12th Feb 2014 2:05am
