![]() | Home > Maintenance & Mods (L322) > Power Supply - Midtronic PSC-500 or Equivalent? |
Ctec get good writ ups on here and Lidl even sold something similar for about £12 in the UK , I think the important thing is to be a multi stage charger with microprocessor control . 2008 MY Supercharged
blueRR2006 Member Since: 13 Jan 2014 Location: Chicago, IL Posts: 38 ![]() ![]() ![]() |
ok, then I'll Bing/Google/ixquick search for a multi stage charger with microprocessor control.
CTEK MXS 5/7/10 should do the job for you without any problems.
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
For reprogramming/reflashing work you need something with a high current output. Guys over on DISCO3 use the CTEK MXS25 for this. The smaller ones don't have the current capacity to supply the vehicle when programming. |
25amp charging power is a bit overkill for a car thats not running, but better safe than sorry i guess.
Add up the current consumption of every ECU that's turned on when the ignition is on and you'll soon be drawing more than that supplied by the small charger.
Guess we are all stuffed then as 50amp chargers are just booster pack rated ones |
Found a PM3-75 on ebay. I know 75 Amps is an overkill, but for the price and peace of mind.
