![]() | Home > Technical (L322) > TDV8 Alternatorh how to change/replacement pics |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Many thanks |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
I think there is a separate relay in the boot on the towing wiring, so should be a simple swap if the drain comes back. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35620 ![]() ![]() |
maybe aftermarket tow wiring has a relay and OE wiring hasnt? |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
The relay is an addition to the lighting, it provides power to a caravan fridge etc. Ian |
^^ yep, spearate to the "fag packet" mounts to the right hand side of the cubby. There is nothing that can't be fixed with a hammer😜😜
blueRR2006 Member Since: 13 Jan 2014 Location: Chicago, IL Posts: 38 ![]() ![]() ![]() |
Hello,
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
With all due respect sir, it's not an easy job for the in-experienced home mechanic and some of the questions your asking are relatively straight forward... Would you not be better off getting a shop or mobile mech to do the swap over for you?
Cam-Tech-Craig,
Mine is a diesel V8 and can't say if yours will be the same.
T24RES,
Neilthesparky Member Since: 18 Feb 2013 Location: Uk Posts: 1 ![]() ![]() |
Lovely job T24RES, my alternator went pop today, short circuit, a few warning messages dead satnav screen parked up, switched off then nothing!! Recovered home just spent 2 hours taking various hoses off, need to sort a 36mm spanner for the fan and then get the offending item out!! Your pictures are a great help,
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
For those of you wondering about the ~2 minute delay before the alternator kicks in - I might have an explanation...
Rovertech Member Since: 25 Feb 2015 Location: Seattle Posts: 20 ![]() ![]() |
1. That's an air conditioning line, and I've never been able to move it without recovering the refrigerant. Workshop manual says to bend it, but I don't recommend that. If you do remove it, you've just contributed to Ozone layer depletion (and broken the law in most countries) unless you Have a refrigerant machine, 2. The radiator hoses always feel stuck. Follow the jar opening advice, but remember they will not turn around, because they are keyed specifically to the fitting. I usually use a flat head screwdriver, and a gentle prying motion. Emphasis on gentle. Patience is key here although you don't have to remove these to get the shroud out. 3. There are 2 small torx screws (t25 I believe), one is on the right side of the shroud as you look at it, about halfway down, hidden below a curve in the shroud, the other is on the right, but closer to the radiator. There are 2 or 3 hoses underneath that are just clipped on to the shroud, one is held on by an 8mm bolt, remove all of those. There's a plastic rivet in the center On the bottom, and 2 on the top. Remove these with a pair of side cutters (don't cut them, just pull the center out). 4. After all of the above is done and you have your fan loose and off the pulley, the shroud and fan will come out as a unit. |
Hello Everyone,
