![]() | Home > My Range Rover > 2005 Facelift TD6 Vogue high miler |
Cheers Gaz |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6742 ![]() ![]() ![]() |
Note to self, must read the thread before replying! ![]() Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
Lloyd Barnes Member Since: 21 Apr 2011 Location: Shrewsbury Posts: 181 ![]() ![]() ![]() |
hi Kingpleb,
Thanks for the thoughts LB |
I most likely will alter the route to skip out a bit of Sweden and Finland should i run short on time as there is a ferry that crosses round and does it in 9hrs odd but also does it overnight as well which is a good way to get a night of rest but still cover a good distance |
Well time for an update!!
Funny, your update on this thread happens just when I was thinking of a Scandinavian trip. I wanted to go Hamburg, Copenhagen, Gothenburg, Oslo, Trondheim, Mo i Rana, Narvik, Tromso, then to the most Northern road in Norway. Route back - Murmansk, St. Petersburg, Helsinki, Talinn, Riga, Gdansk, maybe Berlin.
We could maybe arrange something next year david and take both vehicles. If one breaks the other can at least tow it without breaking a sweat |
I just remember my Croatia/Bosnia trip where the perfect day was no more than 4 hours in the car in the morning, and the rest of the day was devoted to non-car related things. More than that and I felt I was spending too much time in the car. I also spend 5 days in Dubrovnik and hardly used the car at all and that was paradise.
Ha ha, if my numbers come up and i have a really cack day at work i'll probably fuel the car up and go for it |
Well I've put the new varta in and she fires up with some help but runs rough sometimes so I'm going over the log files tonight and will upload the avi's I took as well.
It lives! |
Cheers David, she's still a bit rough so I think wiring loom may be next and a fuel pressure sensor somewhere as well but ideally need to compare to someone's running one |
Bring it round and we'll compare. Could get some skiing in also, if you don't mind being humiliated on the slopes. |
