Home > Technical (L322) > Drivers memory seat |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
You have memory 1234 buttons and 1234 keys... If your key you are using is key 3 for instance, it will set the seat to position 3 set in the memory. Set number 2 to your position, then if that doesn't work number 3 then 4...
24th Jan 2014 9:48pm |
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 |
Thanks for the reply. So what I have done is set the three memory positions on the seat to my preferred setting so t shouldn't matter what key I have. Still when I return to the car, the seat has moved way forwad and all the settings are different I then press 1, 2 or 3 to get it back to the correct place |
7th Feb 2014 7:36pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
i had a similar problem, it turned out that a homeless dwarf was opening up my car and sneaking in a kip! I caught him asleep one morning, and yanked him out of the car!. he said he wasn't happy. so I said, which one are you then?
7th Feb 2014 8:00pm |
7th Feb 2014 8:15pm |
Then it will be the seat ECU at fault |
7th Feb 2014 9:10pm |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 |
Hi does this help ? It says how to set the memory on the seats; http://www.landrover.com/imagery/market/us...tart-guide |
7th Feb 2014 9:32pm |
I have just today after nearly 3 years noticed how the seat does this only sometimes. I could never work out if it was keys or different ways of locking or unlocking and all sorts of combinations of different things that would cause it.
11th Feb 2014 6:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35436 |
you must have the 'vogue haunted' edition range rover.. |
11th Feb 2014 7:07pm |
WHATEVER YOU DO, DONT PLAY THIS SONG IN YOUYR FULL FAT!
11th Feb 2014 8:18pm |
