Home > In Car Electronics (L322) > Bluetooth Funnies going on
jonlewis
2007 Range Rover Vogue TDV8 Buckingham Blue
My bluetooth has started acting strangely............but works perfectly well.
Quite often the phone will be connected... showing connected on the phone.... able to dial out and receive calls, but the display will show "Phone not fitted" unless you happen to be on a call.
Is there a full reset procedure for it as it seems more of a software gremlin than an actual fault ?
BTW, does not matter which phone, seems to be independent of the device. 2011 Stornaway Grey 5.0SC Autobiography
Post #240060 5th Feb 2014 9:04pm
Andy B
I have a not entirely unrelated problem. I-Phone 5 would auto pair no problem after entering the initial pairing code. Upgraded to a 5S and it no longer pairs automatically and I get the 'phone not attached' message Big Cry Censored annoying! SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #240067 5th Feb 2014 9:20pm
JAYBOY
My 2008 used to do it all the time. I just used to go on my phone and say forget this devise and then repair it.
Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #240069 5th Feb 2014 9:23pm
jonlewis
Pairing seems to happen fine.
Have noticed that a guaranteed way to have a flat battery is to switch a call to handset when I get out of the car. Next morning it looks like the bluetooth has kept the car alive all night.
Will try a forget and repair.... but not hopeful. 2011 Stornaway Grey 5.0SC Autobiography
Post #240074 5th Feb 2014 9:28pm
Andy B
Cheers Jayboy, I'll give it a go and see what happens SDV8 AB MY 2019
Post #240079 5th Feb 2014 9:34pm
jonlewis
Tried the un-pairing of the phone and also a physical disconnect of the Bluetooth module and no change.
Starting to think it needs a firmware refresh to get it's self back in order. 2011 Stornaway Grey 5.0SC Autobiography
Post #240584 6th Feb 2014 11:39pm
JW911
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
My particular major funny is that if my phone (4S) pairs to the car - which it always does, without fail (thanks Wiggs) - if I get a phone call at home within about twenty minutes of getting in, the phone defaults to the car (which is now off) so I can't answer it. I have to turn BT off and on again to sort it.
My minor funny - caller ID comes up blank on the TV screen unless the person rings a second time. Works fine on the phone itself.
Question Question Question Question Question Question 2012 4.4 TDV8 Westminster
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #240587 6th Feb 2014 11:43pm
^ I have the same thing with caller ID , as for the phone staying connected to the car I think you are staying in range of the Bluetooth unit and it simply stays connected until the car goes to sleep. 2008 MY Supercharged
Post #240620 7th Feb 2014 12:54am
jonlewis
I think the unfortunate thing is that the car is never going to sleep unless the bluetooth is switched off on the phone..... very inconvenient if honest. It may be that the way my house is laid out means that in most cases I am quite near the car. 2011 Stornaway Grey 5.0SC Autobiography
Post #240649 7th Feb 2014 8:35am
