Home > Maintenance & Mods (L322) > TDV8 oil changes etc. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8516 |
Don't know about the flush but definitely important to drain via both plugs as rear of sump can get gunned up if not done properly and regularly. There is nothing that can't be fixed with a hammer😜😜
20th Jan 2014 8:50pm |
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 297 |
ahh cheers, well it has been serviced by Land Rover main dealer all it's life and they suck it out so that means it has never had its oil sump plugs taken out so I will mostly be doing that in the next few miles.! |
21st Jan 2014 11:28am |
They shouldnt if they follow the proper workshop procedure on it...... There is nothing that can't be fixed with a hammer😜😜
21st Jan 2014 4:36pm |
really? will go and see if I can find the proceedure. |
21st Jan 2014 5:38pm |
nzlandrover Member Since: 30 Jan 2014 Location: Darfield South Island Posts: 5 |
Hi guys.
30th Jan 2014 5:25am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Black patches wherever i park i guess will be more than just filling spillage... |
30th Jan 2014 8:30am |
Not filling spillage,oil from the filter housing removal procedure.The tech thinks the vacuum controlled engine mount has gathered oil in the rubber bellows and is then pumping small amounts onto the subframe.
30th Jan 2014 9:15am |
