Home > Technical (L322) > Deployable side steps not deploying.
kungfupanda
United Kingdom 2014 Range Rover Vogue SE TDV6 Mariana Black
I've recently had a problem with a failing alternator which has resulted in my deloyable steps failing.
I think the problem maybe caused by the battery going completely flat. On the last occasion I drove the vehicle prior to the alternator being changed, the steps were stuck in the out position but when I drove above approximately 10mph, they retracted. Now they have stayed retracted.
Does anyone know of any way to reset the steps at all or is it a trip to the dealers?
Post #238133 30th Jan 2014 12:30am
Just a guess but press and hold the retract button? Works for the sunroof...... There is nothing that can't be fixed with a hammer😜😜
Post #238141 30th Jan 2014 12:40am
Battery reset?
Post #238151 30th Jan 2014 12:54am
Jpickie
United Kingdom 2007 Range Rover Vogue SE Supercharged Stornoway Grey
It sounds like your steps are turned off. Here are the operation instructions, try the very last bit.
Deployable side step operation
To force the steps to stay out regardless of the position of the doors, what LR call 'roof access and jacking mode' get in the vehicle and close the doors, quickly insert the key in the dash and turn to position two, then hold the switch for about five seconds until the light in the switch illuminates continuously then remove the key. The steps will now stay out regardless of the position of the doors unless you drive away or lock the vehicle at which point they will return to their normal function.
If the steps are working and you want to disable them: insert the key in the dash in position 1 and hold the switch whilst turning the key to position 2, the light in the switch will flash twice to confirm the system is now off. To turn the system on repeat the procedure but the light will now flash three times to confirm the system is now on.
Hope this help, regards. Jon MY2007 S/C - Stornoway / Jet
Post #238152 30th Jan 2014 12:57am
kungfupanda
This is so embarrassing. Thanks for the tips. I should have tried the obvious first!
Will let you know how I get on in the morning.
Post #238154 30th Jan 2014 1:00am
Out of interest, how does the above procedure work on a post 09 car without a key?
Post #238155 30th Jan 2014 1:01am
Jpickie
Good question, I don't really know as I have never played with one. I would presume that like with other manufactures there is a way of selecting the aux ( position 1 ) and ignition (position 2) using the stop start button, maybe without putting your foot on the brake pedal and holding the button for a number of seconds, this is the procedure in our Volvo. MY2007 S/C - Stornoway / Jet
Post #238158 30th Jan 2014 1:17am
No sir, ign on or engine running... No ign 1 & 2 Confused
Post #238160 30th Jan 2014 1:20am
kungfupanda
Looks like my steps were turned off and once I re activated them according to Jon's instructions, they are working again!
Cheers Jon and to everyone else with your helpful tips.
Post #238234 30th Jan 2014 2:34pm
