![]() | Home > Maintenance & Mods (L322) > S5 020 Bosch Battery - is it duff? |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Could you fully charge it, leave it for a day, take it back for testing.. It should still be at the top of their scale.. Previously..
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Yes but on the otherhand you have a good brand new alternator in the car, so on that basis i would say the battery is starting to show signs of strain. Personally i find if they have been flattened at all they seem to never be the same again. Car batteries are not designed to deep cycle, unlike leisure batteries which are designed to be run flat more often.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I have an optimate. I've not flattened the battery, it's never failed to start the car. Just dipping on performance which sets off the disco lights on start up. As you say it's fine if used daily but starts messing around if left for a few days. I'll charge it off the car and leave it as Contraband suggests before taking it back to ECP. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Order a replacement from ECP and have them deliver it to you. When they do, tell the driver its a warranty replacement not a payment required job, give the driver back the old one and they will ask you to show the driver the original receipt (i presume its a 3 or 5yr battery) then fill out a form and it will be placed on the warranty pile when the driver gets back to depot... Simples... |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
As Craig says sounds like a great plan, the battery was taking the strain from your old worn out alternator and the damage is starting to show |
Being a private customer, we don't have the dedicated ECP delivery vans. I'm not sure that the yodel man will take the old one back |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35661 ![]() ![]() |
strange you're having problems returning the battery to ECP, i had no problems and they didnt even check mine ...
What a mission that was, changed it after some haggling. Fingers crossed |
After a few days to let the dust settle, i'm still having the disco on start up. By that i mean 'Suspension inactive, HDC inactice, adaptive warning light flashing, bong, bong etc"
You might have to start pulling fuses overnight, to isolate selected systems, and see how it goes. Previously..
This will be my mission over the coming days, once the night shifts have ended. I hate auto-electrics. I have put CTC's number in the hot dial, just in case my sanity fails the distance. |
I would check to see if there is any drain back down thro the alternator when the ignition is off.
