Home > Maintenance & Mods (L322) > S5 020 Bosch Battery - is it duff?
Page 2 of 3 <123>
T24RES
So i've been outside for an hour and connected the meter to the battery, after 25 mins the car is still pulling some amps.
Lent into the cabin and can hear a little fan behind the clock area, here:
This is a video clip:
Is it the FSR that controls this?
Post #239626 4th Feb 2014 4:55pm
pretty sure it is Ian..
Post #239637 4th Feb 2014 5:30pm
The fan behind the controls draws air over the internal air temperature sensor and comes on when the car is unlocked and door opened.
It's fed from the HEVAC ecu. Can't see it being an electrical load of any consequence.
Doesn't have anything to do with FSR. Thumbs Up
Post #239642 4th Feb 2014 5:47pm
Dave, if the fsr was faulty , 'could' it not run the fan when it shouldnt..
Post #239646 4th Feb 2014 6:00pm
Don't think so Stan.
The FSR is on a separate circuit from the ECU and is essentially a stepped voltage output controller varying the speed of the main blower fan only.
I'd be guessing either the FSR is at fault and leaking current or the alternator is suffering failing diodes and leaking current to earth.
As far as I know the FSR can't be tested for performance unfortunately, the drain thro an alternator is fairly easy to check.
It could well be something else causing a current drain but the above two are fairly common and should be positively eliminated before venturing further imo.
Post #239654 4th Feb 2014 6:14pm
thanks mate.. Thumbs Up
Post #239656 4th Feb 2014 6:18pm
T24RES
Why would it still be running 30mins after the car was asleep?
Post #239672 4th Feb 2014 6:43pm
Can't answer that one, I don't know. As far as I know it shouldn't be running when the car is asleep.
I notice from your multimeter you appear to have a current drain of 740mA but I don't think the fan is responsible for this, can't see the fan being responsible for more than about 30mA.
Post #239675 4th Feb 2014 6:53pm
T24RES
Ok, i'll start pulling fuses, beginning with the one for the HEVAC. Don't happen to know which one it is?
I may get lucky Idea
Post #239676 4th Feb 2014 6:55pm
Don't have the fuse listing for 2008, handbook I'm afraid. Thumbs Up
Post #239677 4th Feb 2014 6:57pm
T24RES
Post #239678 4th Feb 2014 6:58pm
T24RES
I can say that the FSR doesn't have anything to do with the hevac fan. I've been in and pulled the connector off, whilst there was a break in the rain.
I've heard of a software update for putting the car to sleep, anyone had this one on a TDV8?
So it's fuse pulling next I guess, at times like this I wish I had a big garage Crying or Very sad Ian
Post #240614 6th Feb 2014 11:42pm
T24RES
Update!
The sun came out for a few hours and i got onto the testing. Having let the car sleep i was still losing 690ma. With the tailgate open and the latch closed on the u/tailgate, allowed the car to rest for 15mins until asleep.
With a fuse puller i started at the 15A tow bar electrics, pulled it and instantly the drain dropped to <100ma (my meter doesn't appear to read any less). Put the fuse back in and the draw remained low Thumbs Up
Fired up the car after refitting the battery and removing meter. With the IID tool reading voltage, 14.8v and 12.9v loaded. A huge improvement, my steering lock has come back to life and all appears well.
Could it be this simple? Was it just a relay in the tow bar electrics stuck open?
I do hope so Thumbs Up
Down side is, i have a perfectly serviceable alternator on the side board if anyone needs one at a discounted price. Ian
Post #241954 11th Feb 2014 3:01pm
Lucky you got that result first go. Thumbs Up
There isn't a relay involved with the toe socket electrics, possibly disconnecting the tow ecu when withdrawing the fuse and re-inserting reset it. Otherwise I've no idea. Very Happy
If you want your multimeter to read in mA just insert the Red probe into the socket marked V1mA.
The Black probe should always be in the Common socket.
Be interesting to see exactly what the drain is.
Post #241960 11th Feb 2014 3:20pm
T24RES
Having fitted the tow bar kit on the FF and an X5 I can say that there certainly is a relay in the kit. Three years ago when I fitted it, I needed to rewrite it as the fridge wasn't working due to the relay being wired from the box incorrectly.
I shall get a snap for you. Ian
Post #241983 11th Feb 2014 4:34pm
Page 2 of 3 <123>
