Home > Technical (L322) > DSC Activating
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
DSC Activating
Driving the FFRR yesterday what I believe is the DSC activated several times when negotiating larger roundabouts. The roads were wet but not that slippery. Symptoms were vibrating (like ABS activating) on what feels like nsr corner and centre yellow light on. Only happens if I accelerate on bigger roundabouts but have been unable to replicate when pulling out and turning left or right or by accelerating in bends.
Search on here finds one case where a suspension part failed later, could this be the problem in which case I will mention to the dealer when going back for other things hopefully next week or are there other problems it could be, assuming it is not normal. If the suspension will there be signs of future failure or will I have to wait for it to fail before I can claim under the dealers warranty. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #237250 26th Jan 2014 2:11pm
Googsy
Could it be the car is out of alignment. Check all your balljoints etc. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #237265 26th Jan 2014 5:21pm
rej
Thank for the suggestion. The FFRR should be going back to the dealer while I am away so will get them to check the alignment. Would the swop to genuine FFRR wheels from replica RRS wheels have any relevance?
Tried to replicate today and only managed to get the DSC to activate twice, both times when about 2/3rds of the way round a roundabout. There is a difference between knowing your sh!t and knowing you're sh!t
Post #237389 26th Jan 2014 10:53pm
aus10RRW
Scotland 2012 Range Rover Westminster TDV8 Santorini Black
Try checking your tyres, my S/C had the same issues going round roundabouts at low speed, turns out there was 1mm difference between the front tyres, bought two new tyres and all sorted!
Post #237811 28th Jan 2014 10:31pm
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
seems more like a tyre issue on wet and possibly cold roads.Check thread depth and check your tyre pressures,might have a slow puncture
Post #237824 28th Jan 2014 11:28pm
rej
Tyres were all new and new RR wheels.
Always seems to be on the same couple of roundabouts unless I try to induce it so maybe just a couple of slippery roundabouts. Never get it with normal cornering or when doing a left circle (opposite way to driving round a roundabout) There is a difference between knowing your sh!t and knowing you're sh!t
Post #244968 26th Feb 2014 10:08am
Swap the wheels FRONT - BACK => BACK - FRONT and see what happens.
Also check pressures. roundabouts are the worst place for such things as they are often littered with diesels/oil splats from vehicles and due to thier tight turning requirements and speed often used with them its easy to see why they are accident zones. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #245015 26th Feb 2014 3:28pm
rej
Thanks, will get a tyre place to swop them around when I get back from my next trip. Only ever had on a few roundabouts so maybe just slippery places as suggested. There is a difference between knowing your sh!t and knowing you're sh!t
Post #245026 26th Feb 2014 4:55pm
JAYBOY
check the sensor Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #245044 26th Feb 2014 6:20pm
rej
Jay,
Which sensor should I check, no errors on suspension or steering using IID tool. There is a difference between knowing your sh!t and knowing you're sh!t
Post #245061 26th Feb 2014 7:24pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Mine does this occassionally....I researched it and there was a Technical Service Bulletin about it, oversensitive ABS / YAW module on 2006MY.
I never bothered about it, doesnt happen that often.... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #245147 27th Feb 2014 7:40am
JAYBOY
Rej
I had the same problem on my defender, Check the ABS sensor. it may have moved a bit. 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #245182 27th Feb 2014 10:07am
