![]() | Home > Technical (L322) > DSC Activating |
Could it be the car is out of alignment. Check all your balljoints etc. Present :2008 TDV8 HSE
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
Thank for the suggestion. The FFRR should be going back to the dealer while I am away so will get them to check the alignment. Would the swop to genuine FFRR wheels from replica RRS wheels have any relevance?
aus10RRW Member Since: 14 Aug 2013 Location: Aberdeenshire Posts: 16 ![]() ![]() ![]() |
Try checking your tyres, my S/C had the same issues going round roundabouts at low speed, turns out there was 1mm difference between the front tyres, bought two new tyres and all sorted! |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
seems more like a tyre issue on wet and possibly cold roads.Check thread depth and check your tyre pressures,might have a slow puncture |
Tyres were all new and new RR wheels.
Swap the wheels FRONT - BACK => BACK - FRONT and see what happens.
Thanks, will get a tyre place to swop them around when I get back from my next trip. Only ever had on a few roundabouts so maybe just slippery places as suggested. There is a difference between knowing your sh!t and knowing you're sh!t
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
check the sensor |
Jay,
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Mine does this occassionally....I researched it and there was a Technical Service Bulletin about it, oversensitive ABS / YAW module on 2006MY.
Rej
