Home > Maintenance & Mods (L322) > [SOLVED] Not starting like wot it did (but runs OK)
For the last five years it has been:
Chatata Vroom !
Last few days:
Chatata Chatata Chatata Chatata Vroom!
Still runs and drives fine once started.
Is the same hot or cold e.g. after a run.
Age? Damp? Glow Plugs (I always wait for the lights to go out) ? Fuel (filter only 20K old)? Dodgy Fuel (from Supermarket Laughing)? Battery (get good starter turnover though)?
I'll pop the IIDTool on when I get a chance .
Post #237489 27th Jan 2014 5:28pm
driving through puddles me thinks.. Laughing
Post #237493 27th Jan 2014 5:42pm
^^^^^ I deserved that Laughing .
Post #237509 27th Jan 2014 7:05pm
Fuel filter?
Post #237521 27th Jan 2014 7:55pm
Mike.Boro
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
Mine started to do that last Wednesday, since then Its been getting more chatata each day, but the drive was fine till Saturday, then a bit rough, today all I get is chatata with no vroom Big Cry Its getting picked up 1st thing in the morning
Post #237525 27th Jan 2014 8:12pm
mjdronfield
Could it be the in line fuel pump struggling to get the pressure up ?
Though to be fair, when mine stopped working, it just didn't start....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #237527 27th Jan 2014 8:20pm
Mike.Boro
Maybe, the is no fuel getting through. Phoned my inde but could not hear what he was saying, as I was being talked at Evil or Very Mad he said something about injectors but not to worry Confused
Post #237533 27th Jan 2014 8:36pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Injector problem I reckon.
Post #237551 27th Jan 2014 9:41pm
Mike.Boro
I think you could be right Paul, with the engine getting a bit bogged down over the weekend and what I've read through the search on the forum. I will see what the inde has to say's in the morning.
Post #237555 27th Jan 2014 10:00pm
Not the battery, charged up and trickled overnight, same 3 or 4 chatatas.
Given it doesn't seem to matter whether the engine/system is up to temperature or not, but it runs fine when started thinking injectors too ? Though I would love it to be dodgy fuel. Will try some injector cleaner next. overdue on this anyway. .
Post #237744 28th Jan 2014 7:37pm
dingg1
How old is the battery ?
even though you say fully charged it may be on its way out and quite simply not spinning the engine over fast enough to get it to fire
are all glow plugs ok?
Post #237747 28th Jan 2014 7:51pm
Could be injector related, my e39 5 series did that one day was instant starting the next was as you say turning over a lot first.
May be something else entirely thogh..... There is nothing that can't be fixed with a hammer😜😜
Post #237765 28th Jan 2014 9:04pm
PaulB
Probably need to do a leak off test.
I had the same on my x5, two injectors were failing by over fueling causing longer cranking before firing up.
The other possibility could be the wiring loom, they are known to fail.
Post #237769 28th Jan 2014 9:09pm
Mike.Boro
Picked my FF up this morning, now running sweet Thumbs Up number 1 injector was shot. Car picked up from my home, injector supplied & fitted £250 Thumbs Up
Post #238007 29th Jan 2014 6:18pm
PaulB
Good news and great price Thumbs Up
Post #238009 29th Jan 2014 6:22pm
