![]() | Home > Maintenance & Mods (L322) > [SOLVED] Not starting like wot it did (but runs OK) |
Helping out on a another thread i found this in my list of faults that I never investigated as i wasn't having any problems:
Time to check this out, seems to make sense as I have a starting up only issue ? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
Poss worse when the weather is colder then ? 2011 Range Rover Vogue SE 4.4 TDV8
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Yes - I did ask the question earlier
It is getting worse, 6/7 chatatas before starting now
but I have had this as a fault since I got the IIDTool ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
It'll manage to start ok in the warmer weather
Not had it in previous years, even when -12 degrees, and it is the same even with a hot engine? .
I know this thread is like ages old.... Did we find an answer.
Yes, it was two knackered fuel injectors.
Magic, thanks. That's pretty much what I was thinking then. Started with turning over a bit longer than it should in the summer, so I don't think it's glow plugs.
