Home > Technical (L322) > Why did I buy a RR? |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
2020 Porsche Panamera Turbo Hybrid (V FAST)
26th Jan 2014 9:44am |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
Google "BMW 4.4 misfire", it seems to be quite a common problem and not necessarily as catastrophic as you may think.
26th Jan 2014 11:21am |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2288 |
Awful experience you have. This is my third second hand FFRR and I never had a major problem. I must say that I bought the last one for 6.5 k through this forum and the only thing I had to do was a small airco repair and a full gearbox flush, car drives and runs great. Seems very reliable. Just telling this to make you aware of the fact that these cars are great, if you not run into a "mondaymorning car" and they exist, every marque has a few examples. Wish you strength with yours, maybe it is not that serious. |
26th Jan 2014 11:52am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
especially when running LPG, i guess its the same on LPG as petrol, all breathers ok, vacuum etc, there is a tonne of pipework on these engines that could cause a problem. have you got an allcomms or any diagnostic kit?
26th Jan 2014 11:54am |
Wooden horse Member Since: 17 Feb 2013 Location: Leicestershire Posts: 6 |
Thanks all, it's good to know I'm not the only one who has issues! It's been on the diagnostics and it shows multiple miss fires but particulary on number 2. The chap I take it to swapped the coil pack from one to two but the issue remained first time but second time it followed it to number 1. Maybe, fingers and toes crossed, he mixed the coil packs on the first test and it's something as simple as that. It was running so well after the service as well, really smooth, exactly as you want it to. T55
26th Jan 2014 3:38pm |
its always scary taking a car to any garage as a simple fault can cause the same symptoms as a major fault requiring a rebuild, and then when they discover the simple fault half way through the rebuild, i cant imagine they would say anything
26th Jan 2014 3:57pm |
Well I have the car back, again! And I must say it is running better than it ever has. Ended up having a full coil pack change, so quite as drastic as an engine strip out but still expensive. Not made my mind up if I'm going to keep it though as really don't want even more major bills. But I have just about had every major part changed in the last 12 months so...
28th Jan 2014 10:51pm |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
Keep. What else is going to give you so much fun. I bought my 04 4.4 back in May with 100k on the clock for £7k. Its now coming up to 125k and yes, its had some routine maintenance - probably cost me £2.5k to catch up on previous owners problems beyond a regular oil and filter change.
28th Jan 2014 11:10pm |
http://www.landyzone.co.uk/lz/f10/l322-mis...34900.html
29th Jan 2014 7:14pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
5 posts in one year
29th Jan 2014 7:27pm |
[quote="holidaychicken"]http://www.landyzone.co.uk/lz/f10/l322-mis...34900.html
29th Jan 2014 10:01pm |
gravitylover Member Since: 08 Nov 2020 Location: Southeast NY Posts: 36 |
Thread resurrection -
29th Nov 2020 4:45pm |
