Home > Technical (L322) > 2010 MY 5.0 S/C AB Belt Screaching - Help Please
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
The last 2 mornings have been very frost and my 2009 59 5.0 S/C AB has been frozen (doors a little stuck etc) and on start up I'm getting a screech which I assume is the auxiliary belt? It goes away after a few gentle revs but without its there for a but longer.
Never had it until now, is a new belt needed or is there something I can do?
Car has 52k miles.
Thanks
Carl
Post #236381 21st Jan 2014 10:33pm
You could try spraying water onto the belt to see if the noise goes away, the effects only last a few seconds but it is a good way to pinpoint the source of the noise.
DO NOT SPRAY WD40 ONTO THE BELT as it will cause damage at a later date
Post #236384 21st Jan 2014 10:50pm
carlos50
Thanks for the suggestion. It was fine this morning, there wasn't any icy weather so its a cold start issue?
Post #236417 22nd Jan 2014 8:52am
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
It's most probably the load on the alternator causing the drive belt to slip. The tension is adjustable, so assuming your belt is in good condition, that's where you should focus attention. Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #236418 22nd Jan 2014 9:00am
carlos50
That,s way above my very limited skills unfortunately unless detailed (with pictures) instructions are available somewhere?, I dare say it looks like a dealer visit then Crying or Very sad
Post #236425 22nd Jan 2014 9:15am
i have this squeak when starting especially after its been wet and cold...it disappears after a few minutes..i brought some hycote belt slip from ecp and kinda sprayed the belt with it but i dont think i got all the belt because of the very limited access to it but the spray reduced the squeaking..
Post #236430 22nd Jan 2014 9:22am
B9er
Or a reputable independent Smile Should've been old enough to know better...doh!
Post #236431 22nd Jan 2014 9:22am
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Gummi Pfledge
Have you tried Einzett Gummi Pfledge on your door seals? It stops them sticking to the door in cold weather, avoiding the chance of tearing the seals. Very easy to apply to the seals.
Fanders
Post #236445 22nd Jan 2014 10:05am
carlos50
I usually do just havent applied it yet, thanks for reminding me to do it Thumbs Up
Post #236455 22nd Jan 2014 11:16am
