Home > Technical (L322) > 2010 MY 5.0 S/C AB Belt Screaching - Help Please |
You could try spraying water onto the belt to see if the noise goes away, the effects only last a few seconds but it is a good way to pinpoint the source of the noise.
21st Jan 2014 10:50pm |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
Thanks for the suggestion. It was fine this morning, there wasn't any icy weather so its a cold start issue? |
22nd Jan 2014 8:52am |
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 |
It's most probably the load on the alternator causing the drive belt to slip. The tension is adjustable, so assuming your belt is in good condition, that's where you should focus attention. Should've been old enough to know better...doh!
22nd Jan 2014 9:00am |
That,s way above my very limited skills unfortunately unless detailed (with pictures) instructions are available somewhere?, I dare say it looks like a dealer visit then |
22nd Jan 2014 9:15am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35279 |
i have this squeak when starting especially after its been wet and cold...it disappears after a few minutes..i brought some hycote belt slip from ecp and kinda sprayed the belt with it but i dont think i got all the belt because of the very limited access to it but the spray reduced the squeaking.. |
22nd Jan 2014 9:22am |
Or a reputable independent Should've been old enough to know better...doh!
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 313 |
Have you tried Einzett Gummi Pfledge on your door seals? It stops them sticking to the door in cold weather, avoiding the chance of tearing the seals. Very easy to apply to the seals.
22nd Jan 2014 10:05am |
I usually do just havent applied it yet, thanks for reminding me to do it |
22nd Jan 2014 11:16am |
