![]() | Home > In Car Electronics (L322) > iOS7 + iPhone 5 + RR Bluetooth issues |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 ![]() ![]() ![]() |
sometimes on my 2007 one.... All my spelling errorz are belong to me!
d3rm0 Member Since: 12 Feb 2012 Location: UK Posts: 440 ![]() |
I assume by the lack of response (apart from Angel, thanks) that it is my iPhone 5 that is faulty which I can get exchanged. The car is a 2012 model |
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 ![]() ![]() ![]() |
Try turning off the phone and back on again! There's been many connection issues with ios7 and aftermarket devices!! |
andrewcuz Member Since: 09 Oct 2013 Location: Boulder, CO Posts: 1 ![]() ![]() |
I have the exact same issue as d3rm0. Phone keeps briefly cutting out, shows "call ended". This happens every 10 secs or so. Problem stops after 5 minutes of call time. Extremely frustrating.
I have wiped the iPhone and reinstalled a backup with no joy. My 2013 5 Series doesn't miss a beat |
Rotorboater Member Since: 26 May 2013 Location: UK Posts: 36 ![]() ![]() ![]() |
I have the same problem, iPhone 5s and 2012 RR, it's getting really annoying, I get cut off for a few seconds and my caller hears my radio, is this just a RR problem or is it an iPhone issue? |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
I have a 5s with iOS7 and it works fine in my MY11. I do however have the digital TV country selected as the USA to temporarily overcome the intermittent interruptions due to some recent change in the digital program guide transmissions. Maybe this is what is causing your problem? Worth a try I'd have thought. 4.4 TDV8 Vogue Baltic Blue MY11 |
I thought it was related to the DVB issue but like others I have had the TV set to USA from the beginning. I haven't been driving my FF for the last couple of weeks so I haven't experienced the issue, it's a 12MY. My BMW F10 is a 2013 and is perfect with iOS7 so it does point towards a Land Rover issue. I think it maybe a Bluetooth compatibility issue. All you can do is report it to the dealer. |
Thanks Baron, that's sorted it |
Jareer Member Since: 30 Oct 2013 Location: Amman Posts: 1 ![]() ![]() |
I have the exact same problem and the TV adjustment as suggested by Baron did not work.
warren1712 Member Since: 18 Feb 2010 Location: Across from the Trout Lake Posts: 35 ![]() ![]() ![]() |
USA selected and iPhone 5 still cuts on and off |
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 ![]() ![]() ![]() |
I have the exact same issue, IOS7 iPhone5 and L322 2010
Tried the TV setting change and if anything it makes it worse.
The solution is, switch to Samsung |
