Home > Technical (L322) > Radio without Key? |
I thought one has to hold down the power button to get the radio on?
28th Jul 2010 6:44pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35255 |
dont know re the radio dan but i have found that mine only goes to access level when stopped and engine running... |
28th Jul 2010 6:57pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
There is a very short time delay on the access button after the engine is stopped, not sure if the key still needs to be in with ignition off, got a feeling it will work for about 15 seconds after key removal as long as no doors have been opened. Discovery 4 HSE
28th Jul 2010 9:09pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
I can turn my radie/cd etc on without the key, I just press the audio power button. It also appears to limit the volume level, presumably to reduce current draw on the battery. As for access button, with the ingniton off (but key still in) I think I have a few seconds to hit the button else nothing happens, but I always do it just prior to turning the ignition off and before anyone opens their doors as a rule. Steve
28th Jul 2010 10:27pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Suspension changes WILL not occur with an open door. Also all windows etc will cease to be powered after opening the doors.....
28th Jul 2010 10:38pm |
I have a 2003 radio guys....
28th Jul 2010 10:57pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
Does anyone else have the 'total closure' enabled on their keyfob?
29th Jul 2010 12:11pm |
the total closure/open works on mine, dont know whether it was programmed by dealer or not.. |
29th Jul 2010 12:43pm |
It was a comfort option on my 2006. I have it by default on my 2010 so I guess it's now standard. Land Rover Addict
29th Jul 2010 1:34pm |
Yeh, works for me. |
29th Jul 2010 2:56pm |
Not that different to my 2004 then Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
29th Jul 2010 3:04pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Dan, how are you going to fit a pre heater? Isnt yours a petrol/LPG? As far as I know, you can only do this with diesel as its not flammable in the normal sense. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
30th Jul 2010 11:59am |
My business partner has a 2010 SC with a pre-heater, and his previous 2006 SC was too. From factory as an option - I am not that namby pamby Land Rover Addict
30th Jul 2010 1:38pm |
The 4.4 Vogue had a pre-heater option and it's listed in microcat... You can run a wabco pre-heater on petrol no problem, just obviously need the correct model. I believe you can even convert a derv one but it's a lot of hastle. N e hoo.... I'm going for an electrical option, similar to the Kenlowe hot start kit. Dan |
30th Jul 2010 2:25pm |
