Home > Technical (L322) > 2011-2012 Land Rover HDD Navigation Disk in a 2006 RR HSE |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35324 |
after inserting disc one, insert disc two.........disc one is probably a firmware upgrade and disc two is the mapping disc. |
20th Jan 2014 8:40pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
Reckon Stan is onto something, as disc one you show as having an apl version which I think is a version of the firmware, and as disc 2 is also showing the map version as the same as disc 1 the I sum miser that disc 1 is the firmware and 2 is the functional map disc.
20th Jan 2014 8:46pm |
blueRR2006 Member Since: 13 Jan 2014 Location: Chicago, IL Posts: 38 |
ok, is there a duration time I should be waiting for? There is no indication on the display anything is happening. Should RR be running or just have ignition in III position?
20th Jan 2014 9:07pm |
Have you tried putting disc 2 in? There is nothing that can't be fixed with a hammer😜😜
20th Jan 2014 9:09pm |
yes right after disk 1, display didn't change. I'll go back out to garage in a few and try again. 2006 Range Rover HSE 4.4L Jag Engine/ Buckingham Blue |
20th Jan 2014 9:12pm |
