Home > Maintenance & Mods (L322) > Glow plugs replacement
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
Anybody done this to their TD6 can't really find any diagrams on this managed to do all the filters but not yet Sussex the glow plugs? Any help and pics would be great
Many thanks
Stu F**K IT you only live once
Post #170400 6th Feb 2013 12:21am
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
Is it having trouble starting?
I only ask because a lot of people think they are like spark plugs, and are a service item. They are not. They only need replacing when they fail.
Regards, Luke
Post #170568 6th Feb 2013 9:02pm
stuboy00
Yep sometimes it's real bad when its cold
Cheers F**K IT you only live once
Post #170570 6th Feb 2013 9:08pm
RCusden
Wales
If you take the top engine cover off and possably need to take the top part of the inlet manifold off you will see them on the top of the head. Be warned use plenty of wd40 as they ceize in nicely as some previous mechanic found out on mine and snapped no 1 glow plug off flush with the head Big Cry now I only have 5 heater plugs working but it has never failed to start have you checked the glow plug relay can you hear it click off after about 20-30 seconds after you turn the ignition on I would check that first as changing the plugs is not a job for the faint hearted
Roger
Post #170573 6th Feb 2013 9:21pm
stuboy00
Thanks for that but I've checked all wiring, relays etc got a new battery also so I'm pretty sure it's the glow plugs
Thanks F**K IT you only live once
Post #170575 6th Feb 2013 9:29pm
RCusden
Wales
When yours does start is it very smokey unburnt fuel as mine was slow to start and I found it to be the input fuel pipe on the high pressure fuel pump. ( hence the reason I know where the heater plugs are )
Roger
Post #170583 6th Feb 2013 10:08pm
stuboy00
Hi roger no smoke once it starts just had a thought I only use bio fuel wonder if that might be affecting the glow plugs? Just a thought F**K IT you only live once
Post #170588 6th Feb 2013 10:32pm
RCusden
Wales
Could be something to do with the fuel don't know to much about bio but used to run vans and disco's on veg oil and they would take a lot of cranking when cold as the fuel thickens up. Normally if there is a glow plug issue when it does start it would smoke and the fumes will smell of unburnt fuel.
Post #170604 6th Feb 2013 11:08pm
You could be experiencing waxing with the fuel as while some places and suppliers say they put winteriser in, they often dont to cut costs. Stick 20litres of dino in to about 1/4-1/2 a tank and see if it helps.
Also after the glowplug light goes out give it another few seconds as this gets the secondary pump enough chance to pump the thicker fuel.
If you do replace the plugs i think bosch do some duraterm ones for the M57 engine. They are well worth the money and used in BioD circles as they are double wound for extra heat Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170622 7th Feb 2013 12:06am
stuboy00
Cheers kingpleb will do that before I change the plugs see what happens Wink F**K IT you only live once
Post #170637 7th Feb 2013 8:08am
Dazzler
England 2003 Range Rover Vogue Td6 Zambezi Silver
Roger
Hello there my td6 is doing just that, may i ask how to fix the input pipe?.
Is the high pressure pump under the offside rear ??? Thanks Darren
Post #235582 17th Jan 2014 8:12pm
RCusden
Wales
The high pressure fuel pump is on the engine as you look at it from the front it's on the right hand side under the plastic cover. Mine was leaking fuel from there so I could smell the fuel when the engine was hot.
Post #235597 17th Jan 2014 9:00pm
Dazzler
Thankyou will have a look see Smile
Post #235601 17th Jan 2014 9:07pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
you only need to remove the inlet manifold to get to the glow plugs. a little tip though if you try to remove the glow plugs with a cold engine you will most likely break one in the head, once the manifold is off start the engine and leave it to idle until its up to temp then you will find with a some help from some wd they will all come out.
Post #235613 17th Jan 2014 10:22pm
