![]() | Home > Maintenance & Mods (L322) > Glow plugs replacement |
stuboy00 Member Since: 09 Feb 2012 Location: Glasgow Posts: 251 ![]() ![]() ![]() |
Anybody done this to their TD6 can't really find any diagrams on this managed to do all the filters but not yet Sussex the glow plugs? Any help and pics would be great
Yep sometimes it's real bad when its cold
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
If you take the top engine cover off and possably need to take the top part of the inlet manifold off you will see them on the top of the head. Be warned use plenty of wd40 as they ceize in nicely as some previous mechanic found out on mine and snapped no 1 glow plug off flush with the head |
Thanks for that but I've checked all wiring, relays etc got a new battery also so I'm pretty sure it's the glow plugs
When yours does start is it very smokey unburnt fuel as mine was slow to start and I found it to be the input fuel pipe on the high pressure fuel pump. ( hence the reason I know where the heater plugs are )
Hi roger no smoke once it starts just had a thought I only use bio fuel wonder if that might be affecting the glow plugs? Just a thought F**K IT you only live once |
Could be something to do with the fuel don't know to much about bio but used to run vans and disco's on veg oil and they would take a lot of cranking when cold as the fuel thickens up. Normally if there is a glow plug issue when it does start it would smoke and the fumes will smell of unburnt fuel. |
You could be experiencing waxing with the fuel as while some places and suppliers say they put winteriser in, they often dont to cut costs. Stick 20litres of dino in to about 1/4-1/2 a tank and see if it helps.
Cheers kingpleb will do that before I change the plugs see what happens |
Dazzler Member Since: 09 Sep 2013 Location: West Sussex Posts: 34 ![]() ![]() ![]() |
Hello there my td6 is doing just that, may i ask how to fix the input pipe?. Is the high pressure pump under the offside rear ??? Thanks Darren |
The high pressure fuel pump is on the engine as you look at it from the front it's on the right hand side under the plastic cover. Mine was leaking fuel from there so I could smell the fuel when the engine was hot. |
Thankyou will have a look see |
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
you only need to remove the inlet manifold to get to the glow plugs. a little tip though if you try to remove the glow plugs with a cold engine you will most likely break one in the head, once the manifold is off start the engine and leave it to idle until its up to temp then you will find with a some help from some wd they will all come out. |
