![]() | Home > Maintenance & Mods (L322) > Bosch Aerotwin blades |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
I have searched the site but cannot find any info on here about the Bosch Aerotwin wiperblades being fitted to TD6.
Short answer is no it can't be done , the FullFat has a "special" fitment .
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3866 ![]() ![]() ![]() |
I have one on the back (aero twin that is) but the fronts are still Bosch 808 which are ARAIK the only option Geoff |
^ I once fitted one to the back and then thought what is the point ? there is no proper air flow over the rear window |
The back window wiper on my car has never cleared water properly. Both sides of centre the blade seems to clear the window and then make contact again. It is almost like the rear screen is dented on both sides. I have tried new blades and just threw one away that had rusted badly which I thought a bit strange as they are designed to woirk ewith water.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
you need 2x P38 drivers side arms I think. drill the centre of and bolt on. sinple by all accounts. bought a set of arms from ebay just needed to source a 2nd drivers arm. Never got round to doing it before I sold the car. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Yep, complete waste of money on the back, but the blade does clear the back screen nicely so whats £20 between friends |
