Home > Maintenance & Mods (L322) > those little hooks in the luggage area
73vse
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
does anyone know the part number for the little black plastic hooks in the luggage area that are used to lock the interior panels in place ? There are 4 on each side .. I'm missing one
Post #233173 6th Jan 2014 11:11am
Send Dan @ Duckworths a PM Thumbs Up Discovery 4 HSE
Post #233187 6th Jan 2014 1:04pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
hi, sorry for delay in picking this up. I've got some in my garage and you are welcome to have one if you like!! there is the black hook and a white inner piece that it locks into. I could give you the part numbers if you like.
black hook...AWR4375PUY
white inner...LR004797 Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #234349 12th Jan 2014 7:56pm
Mustard
I got a stack of these from 'Dan the man' (Duckworths) not long ago, they arnt expensive at all
Post #234370 12th Jan 2014 9:45pm
73vse
I assumed I'm just missing the hook, I'd better check to make sure the white bit is there
Post #234386 12th Jan 2014 10:33pm
73vse
looks like I'm missing the white bit as well
Post #235353 16th Jan 2014 6:17pm
stu
you are more than welcome to come to uncle stu's garage, as I have the bits you require. Where are you in the county? I Live in Catterick Village, but work in Harrogate. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #235372 16th Jan 2014 7:27pm
Dolphinboy
Stu, save me one of the white ones if you would please. Will be passing by in a while so can pick up (or can pm u my address for a mailout??! Thumbs Up )
Post #235383 16th Jan 2014 8:53pm
73vse
Huge thanks to Stu Very Happy
Met up tonight, chatted cars and picked up a couple of hooks Cool
Post #235605 17th Jan 2014 9:33pm
