Home > In Car Electronics (L322) > Freeview TV Guide
Andy B
Freeview TV Guide
Hi,
Fitted a digital TV tuner (Land Rover hybrid) to replace the old analogue unit. Can't seem to pick up the Freeview menu. It is picking up a signal and by fiddling with the PAL settings I can get BBC1, BBC4, Pick TV, Challenge etc, but the tuning buttons don't work. Duff unit or me being thick?!
Any advice appreciated!
Cheers,
Andy.
Post #235082 15th Jan 2014 12:47pm
its nothing like the freeview you get on a standard tv ...there's no epg or radio stations..
Post #235083 15th Jan 2014 12:55pm
I get Freeview exactly as at home including radio stations.
Never had a look for epg, must have a look for it.
Post #235084 15th Jan 2014 1:00pm
Andy B
It seems to pick up 1 station at a time and only by changing from PALB to PAL I (for example) will it pick up a different channel. Don't know if there are any '753 hack' settings that I could amend to make it work. btw it's a 2006 S/C
Post #235085 15th Jan 2014 1:07pm
Andy is referring to the OE hybrid tuner NDFI...the aftermarket jobbys will be the same as the normal house tv's...
according to the manual Andy, you click on auto and it stores whats available in your area..you can select UK from the menu as well..
Post #235086 15th Jan 2014 1:09pm
Post #235088 15th Jan 2014 1:12pm
Andy B
Thanks chaps, the setting is on 'United Kingdom' but the 'Auto' button doesn't seem to do anything....neither does the manual tune for that matter! It's all a bit strange Sad
Post #235090 15th Jan 2014 1:18pm
not sure on this one Andy, maybe a battery reset or [guessing now] you might have to do something in the ccf to active the tuner ?
Post #235093 15th Jan 2014 1:24pm
Andy B
Thanks Stan. It has recently had a reset due to a battery replacement and also at the last service they had to do a hard re-boot as the ECU locked out and wouldn't reset the service indicator (Range Rovers, don't you just luv 'em!). What is the ccf (please excuse my ignorance!).
Cheers,
Andy
Post #235095 15th Jan 2014 1:29pm
ccf= car configuration file.
these are from the user manual ,might help..
Post #235100 15th Jan 2014 1:48pm
Andy B
Cheers Stan, that's really helpful thanks.
I'll have a further 'fiddle' later today. I assume the dealer could look at the CCF for me, unless you know of a reasonably priced diag/config tool?
Thanks,
Andy
Post #235102 15th Jan 2014 2:11pm
an IIDtool would be a wise investment as it can also clear faults..
Post #235104 15th Jan 2014 2:24pm
Andy B
Cheers Stan, was looking at these before Xmas and they look good value. Maybe time to invest methinks!
Thanks,
Andy
Post #235115 15th Jan 2014 4:07pm
stu
The factory fitted hybrid digital tuner has no EPG, but the later units have it. I have EPG along the bottom of the screen. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #235607 17th Jan 2014 8:45pm
on your 2007 Stu?
Post #235621 17th Jan 2014 9:53pm
