Home > Maintenance & Mods (L322) > Rear View Camera
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Rear View Camera
I have been looking through the threads and based on what I have read I think I have a CMOS camera which is the worst quality and only works part of the time.
If I have understood correctly if I upgrade to the 2010 HD/Hi Res camera I need to cut and join wires and move the camera mounting point so more than I would wan to do.
It appears that there is an in between option of a CCD camera which has a slightly better picture (probably acceptable as I only want to see what is behind me to check for low walls etc...
I have counted out aftermarket although possibly cheaper as I would prefer to keep near OEM and not hack wires etc...
Question is the CCD a straight swop for the CMOS, i.e. same connectors and mound and if so where can I get one and the rough price. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #235066 15th Jan 2014 11:41am
there's this in the wiki that might be of interest or you could try a forum search,
http://www.fullfatrr.com/forum/topic4621.html
Post #235080 15th Jan 2014 12:44pm
rej
Thanks Stan, had seen that and a couple of others but they involve after market cameras and / or having to cut in to the wiring. I don't need HD quality, just a clear image of what's behind and out of view of the mirror. I am looking for as simple as possible or I will have to pay someone to fit and risk other electric problems. There is a difference between knowing your sh!t and knowing you're sh!t
Post #235098 15th Jan 2014 1:34pm
i dont think there is anything definitive re this on the forum but here's a link from a search i did,there might be some info that could help you..
http://www.fullfatrr.com/forum/search.php?...rch_time=0
Post #235101 15th Jan 2014 1:55pm
