Home > Technical (L322) > Gearbox - stuck in 3rd or 4th gear? |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1247 |
Sounds like a gearbox overheat problem and the box has gone into 'safe' mode. Do a search on 'transmission overheat' |
13th Jan 2014 2:03pm |
gerymor Member Since: 09 Apr 2012 Location: Derbyshire Posts: 35 |
Thanks Paul, Could the opposite - cold - have same affect? It was straight out of the garage this morning near Buxton, about 2 degrees above freeze, stone cold. overheat not possible. |
13th Jan 2014 2:23pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Mine did it a few weeks back, locked in 4th, was told to look at the battery, see my post..Bong..
13th Jan 2014 3:37pm |
fairwx Member Since: 10 Nov 2011 Location: bristol Posts: 124 |
Take it to the dealer, I assume they can check the log and tell you what the fault codes are. |
13th Jan 2014 3:44pm |
