Home > Technical (L322) > Gearbox - stuck in 3rd or 4th gear?
gerymor
Hi has anyone experienced this, can anyone suggest best action or ignore?
Backed the RR out of garage this morning ok but set off forward very weak on power, quickly became apparent stuck in a higher gear, (30mph exactly 1500 revs) Manual levers did not operate either. Did about 10 miles staying under 50mph on the school run. After switch off, short rest and restart problem has gone away and "gearbox fault" no longer on dash.
Vehicle done 50,000mls and has two months to go to end of LR warranty, and I've recently had a new full gearbox cost on my wifes Freelander 2, so worrying that it may be contagious!
I kind of wish it were still broken, then I could get a warranty fix! is it a sign of trouble to come? Should I report it to dealer?
It's a MY/11 4.4 TDV8 SE.
Thanks! Thumbs Up
Post #234492 13th Jan 2014 1:20pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Sounds like a gearbox overheat problem and the box has gone into 'safe' mode. Do a search on 'transmission overheat'
Post #234494 13th Jan 2014 2:03pm
gerymor
Thanks Paul, Could the opposite - cold - have same affect? It was straight out of the garage this morning near Buxton, about 2 degrees above freeze, stone cold. overheat not possible. Confused
Post #234498 13th Jan 2014 2:23pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Mine did it a few weeks back, locked in 4th, was told to look at the battery, see my post..Bong.. Thumbs Up
The trans fail safe has not returned back so i'm guessing battery was a tad low with mine, hope yours is as simple fix as mine was. Cool If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #234532 13th Jan 2014 3:37pm
fairwx
2015 Range Rover Vogue SE SDV6 Luxor
Take it to the dealer, I assume they can check the log and tell you what the fault codes are.
Post #234535 13th Jan 2014 3:44pm
