Home > In Car Electronics (L322) > Bizarre radio gremlin |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35117 |
seems likely.. |
11th Jan 2014 10:01pm |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 |
Man of many words. Next! |
11th Jan 2014 10:12pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Search |
11th Jan 2014 10:52pm |
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 |
Check around your bluetooth module as this usually soaks up the water first,
11th Jan 2014 10:55pm |
I did search which is why I put the last part of the post. |
11th Jan 2014 10:57pm |
Thank you! Oh no it's freezing tonight! That's my Sunday morning sorted then! |
11th Jan 2014 10:59pm |
Its a real pain in the but you must get the water ingress sorted out asap. Mines bone dry these days but it took a fair bit of elbow grease & pound notes to get it that way. Have a decent breakfast and get stuck in to see if your suffering another god dam land rover common fault |
11th Jan 2014 11:38pm |
It is a common problem.
11th Jan 2014 11:41pm |
11th Jan 2014 11:44pm |
12th Jan 2014 12:25am |
Appears to be an egg cup worth of water in the spare wheel well. Cleaned up, no corrosion or damage to any electrics. I can see at the corner of the left hand seal at the bottom it's not as flush as the other side. I will order a new seal. May check warranty to! Although as the name of the day ends in 'y' it's probably a no. |
12th Jan 2014 12:10pm |
You still need to find where its coming from, if its coming in at the bottom of the seal I doubt this would affect the electrics panel on the side. Pop the D pillar internal plastic trims off and see if the wadding on the back is wet, also put something like a swing bin liner around your electrics and then pack in some pieces of kitchen towel or bits newspaper pages on the top of it all and leave it for a couple of days, check back for any evidence of water showing up, may take a few good showers to do it though..... |
12th Jan 2014 9:26pm |
Ahhh ! Back out at the weekend! |
14th Jan 2014 11:28pm |
Its raining hard out there, you leaking ? |
14th Jan 2014 11:31pm |
