Home > General > Weird headlight thing
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
On main beam, my headlamps seem to flicker. At the top of the beam throw it flickers and moves around. This is only coming from the xenon bulb and only happens when on main beam. It's really noticeable and would probably fail an MOT.
Anyone experienced this / got any idea's??
I'm going to get it in to landrover next week if not.
Post #21107 26th Jun 2010 12:51am
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Hello hoppy - I offered Nappler a suggestion to this problem yesterday.
When you can - have a look at my explanation on page 2 of the LANDROVERmax! Show 28th - 30th Aug thread in this sites EVENTS section.
Unfortunately, I think it will be your ballast resistor failing, which means a new headlight unit Sad
Good luck - I hope i'm wrong! Rolling Eyes
Post #21111 26th Jun 2010 5:01am
hoppy_70
I hope your right! It still has a month left on the warranty.... Headlights would be covered wouldn't they??
Post #21115 26th Jun 2010 7:29am
delamo
Yes, they should if its original manufacturers warranty - which yours is being 2007 Thumbs Up
Make sure they acknowledge the problem / cause - my dealership didn't think anything was wrong when the problem first started - (within warranty) the flickering wasn't that noticable at first, then denied all knowledge when it went pop! (out of warranty)
Not only did they want to charge full whack for a headlight unit - there was labour charges also explaining that the front end (bumper etc.) had to be striped to remove headlight!
They lied!...
I 'fixed' my light by buying replacement headlamp from eBay and swapping the boxes (after a short time this also developed a flicker)
In the end - I part exchanged the car back to the dealer (still with the problem Twisted Evil)
The ballast resistor is the metal box which is fixed to the back of headlight unit (about the size of pack of cards) Despite being fixed in place with 3 Torx screws, LR insisted that this item is not available / sold seperately and you need to replace complete headlamp assembly.
Post #21129 26th Jun 2010 1:35pm
hoppy_70
Well it took 4 attempts at the dealers but finally got
Both headlamps changed today under warranty. Ive no doubt that if I hadn't kept banging on about ballast resistors they would have fobbed me off.
Thanks delamo, much appreciated! My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #23267 26th Jul 2010 9:38pm
delamo
Smile My pleasure - glad that I was able to help out Thumbs Up
Post #23273 26th Jul 2010 9:56pm
hoppy_70
To the tune of £900! My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #23359 27th Jul 2010 4:14pm
