![]() | Home > In Car Electronics (L322) > Reversing camera and RSE malfunction |
ksskaret Member Since: 27 Oct 2013 Location: Tromsų Posts: 73 ![]() ![]() ![]() |
When I started my RR the other day the reverse camera and the RSE didn't work. After a 200 km drive I stopped and started the car. Suddenly everything was in order.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
battery would be the first thing to check.. |
I did a battery voltage test with engine turned off, it gave 12,6 volts. Then i turned the engine on and it vent up to 17,5 volts and stayed there |
17.5 volts is to much and will have fried the battery...sounds like a new alternator and battery unless the regulator is replaceable item... ... - .- -.
Yes, way to much |
