Home > In Car Electronics (L322) > Reversing camera and RSE malfunction
ksskaret
Norway 2010 Range Rover Autobiography TDV8 Santorini Black
When I started my RR the other day the reverse camera and the RSE didn't work. After a 200 km drive I stopped and started the car. Suddenly everything was in order.
Could this be due to low voltage or a broken battery?
Simon Smile Range Rover TdV8 Autobiography MY2010
Defender 110stw Td5 MY2006
Post #229599 16th Dec 2013 5:08pm
battery would be the first thing to check.. Thumbs Up ... - .- -.
Post #229614 16th Dec 2013 6:27pm
ksskaret
I did a battery voltage test with engine turned off, it gave 12,6 volts. Then i turned the engine on and it vent up to 17,5 volts and stayed there Exclamation Confused
I guess this indicates a broken battery and an alternator due for replacement Question Range Rover TdV8 Autobiography MY2010
Post #231957 30th Dec 2013 8:36am
17.5 volts is to much and will have fried the battery...sounds like a new alternator and battery unless the regulator is replaceable item... ... - .- -.
Post #231961 30th Dec 2013 9:01am
ksskaret
Yes, way to much Evil or Very Mad Had the same fault occurring on my D3 after 6 years, the alternator burned up Neutral Range Rover TdV8 Autobiography MY2010
Post #231976 30th Dec 2013 11:43am
