Home > Technical (L322) > CYCLE RACK aargh.
Major delays in Rouen when we came down at the start of July - a multi month road closure because of major road works on 'Pont Mathilde' (Mathilde Bridge). The diversion is, quite frankly, a joke & we queued for ages.
Do a search and there are a number of references, but I'd give Rouen quite a wide berth if travelling at peak hours.
I've already booked an overnight stop in Rouen for the way home - non-refundable - so will plan to arrive late and leave early.
Post #203431 11th Aug 2013 1:54pm
Rouen will be bad, the autoroute underpass is still closed, we travelled to normandie via tunnel and then across through le havre to avoid rouen only to get stuck in le havre at pont normandie. Terrible q.
I think if you plan ahead and work out a sufficient re route past the known badpoints you should mostly be ok, there was a workaround at le havre but with the van on i didnt want to risk getting sent down a dead end or narrow street, its happened to me before...... There is nothing that can't be fixed with a hammer😜😜
Post #203440 11th Aug 2013 3:14pm
leem5
Gents, can I ask if one of these is the rack that you have bought, as I am after one myself now.
http://www.halfords.com/webapp/wcs/stores/...yId_165477
Cheers,
Lee
Post #231948 30th Dec 2013 1:30am
Top one Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #231956 30th Dec 2013 8:33am
kiter
same here Thumbs Up
Post #231958 30th Dec 2013 8:45am
Post #231959 30th Dec 2013 8:56am
leem5
northernmonkeyjones wrote:
Top one Thumbs Up
Great stuff, thank you. Shall go and pick one up.
Lee
Post #232034 30th Dec 2013 6:05pm
Post #232039 30th Dec 2013 6:32pm
RR1234
2014 Range Rover Autobiography SDV8 Luxor
47p2 - I like that Ateria rack. Where can I get one? How much?
Post #232042 30th Dec 2013 7:20pm
^^^ Roofbox Click Thumbs Up
Post #232049 30th Dec 2013 7:46pm
RR1234
Thanks for the detail & apologies for not replying sooner. Razz
Post #233075 5th Jan 2014 6:13pm
No problem Thumbs Up
Post #233109 5th Jan 2014 7:41pm
