Home > Technical (L322) > trans failsafe prog |
alib123 Member Since: 29 Dec 2013 Location: essex Posts: 20 |
anyone have any ideas?? |
30th Dec 2013 1:47pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 955 |
Your ‘bass speaker’ rumble may well be caused by wear in the torque converter lock-up clutch but this doesn’t usually cause other issues with the 5HP24 and you could potentially continue for thousands of miles yet with the lock-up clutch in this condition and not cause any damage.
2nd Jan 2014 11:13am |
Thanks for your help and info Phil. I have followed your advice and can report the following.
7th Jan 2014 2:37pm |
Sorry forgot to mention, can select hi low with no problems (obv not when locked in trans safe) and battery is fine. |
7th Jan 2014 2:39pm |
If your transmission fails safe to 4th gear then it would appear that your A-clutch is okay. Fluid temperature dependency usually indicates internal seal leakage. I think the best thing to do next would be to get the codes read, but you would need to use a high level diagnostics kit like Testbook/T4 or Autologic to get the Land Rover specific transmission fault codes, and not just some generic OBD kit
9th Jan 2014 9:53pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Mine showed up this message, only did it once a few days ago. All I did was charge the battery up on trickle charge, was told to check battery, even though it is new.
9th Jan 2014 11:26pm |
Update, looks like its a problem with the hydraulics and the b clutch. Ive been quoted £2500 plus vat for a full rebuild. I cannot afford that so does anyone know or recommend anyone in essex/kent to do the work? |
14th Jan 2014 3:18pm |
Do you happen to know what fault code led them to believe there was a problem with your B-clutch? I’ve never heard of a 5HP24 'failing safe' to a gear that required the clutch that it had just detected a fault with. The B-clutch is used in 4th gear & 5th gear, of course.
14th Jan 2014 4:44pm |
Hi Phil, I dont know the fault code yet, sorry. He just said that it locked into 3rd on his test run and when he diagnosed it it said hydro prob and b clutch. Il try to find out more. Im also looking for an exchange unit as this maybe cheaper option thsn rebuilding mine |
14th Jan 2014 5:29pm |
Could it be gearbox overheating that would explain the hard driving factor. I have known these symptoms before.... |
14th Jan 2014 8:02pm |
