Home > Maintenance & Mods (L322) > egr
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
egr
hi, im going to do the egr removal in the next couple of days and just making sure this bit in the pic is blanked off, correct ? Thumbs Up Steve
Post #231615 27th Dec 2013 3:54pm
Certainly is. Thumbs Up
Post #231616 27th Dec 2013 4:09pm
greasemonkey1
United Kingdom 2005 Range Rover Vogue Td6 Java Black
. thats correct Thumbs Up ... enjoy the mod...
Post #231624 27th Dec 2013 5:05pm
How are you going to blank it ? .
Post #231628 27th Dec 2013 6:28pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
Left the egr in place on mine, although i did remove it to clean all the carbon Censored out of it and made sure the valve was fully closed. Put it back on but left the vacuum tube off and blanked the end of it. Does the same as the removal kit but cost nothing Very Happy . '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #231642 27th Dec 2013 7:16pm
Steverr
With the blanking kit I bought
Post #231643 27th Dec 2013 7:21pm
Steverr
Wish I knew that... Sad Sad wouldn't of bought the blanking kit !!!! Big Cry
Post #231644 27th Dec 2013 7:23pm
wats39
On the plus side though, at least you wont have to clean all the Censored out of the egr. Thumbs Up '04 td6 se
Post #231645 27th Dec 2013 7:33pm
Thought you may have found a shiny metal disc of suitable size to poke in the end of the exhaust gas inlet Confused
@ wats39, tried all that with mine, didn't make a blind bit of difference to mpg or performance, wonder if my valve wasn't properly closed, although it was one heck of a push to get it moving...... .
Post #231671 27th Dec 2013 11:47pm
wats39
The valve should be closed when there is no vacuum Joe90 so yours must have been stuck open. Not surprising though with the amount of carbon you find in them. I gained around 2-3 mpg after disconnecting it. Also got peace of mind that the engine isnt breathing in all the carbon Censored too. Thumbs Up '04 td6 se
Post #231762 28th Dec 2013 5:28pm
Steverr
How long does if take to do ? Also did you use fire gum on the blank off bit. Can I use silicone ?
Post #231775 28th Dec 2013 7:46pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
less than an hour including tea and a bacon roll..............its a very straightforward mod happy to help if you want a trip down south
Post #231777 28th Dec 2013 7:53pm
greasemonkey1
about 20/30 minutes done unrushed,,i used gum gum as that is well known for its reliability when it comes to blocking out exhaust fumes..
Post #231900 29th Dec 2013 6:43pm
