![]() | Home > In Car Electronics (L322) > Samsung S3 Pairing |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
No - But you do need a BT module with a more up-to-date firmware tho
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
So the issue is at the car end, not the phone end ?
Yea - mine did the same on my 07MY / SII until I 'upgraded' the BT module. |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
My stock 2007 TDV8 pairs with my S3 no problem. Don't forget to set the phone to auto connect in the BT settings when you first do the pairing. If it hasn't worked properly the fist time unpair and do it again. 2012 5.0L S/C
Can't see auto-connect on the S3 ?? Is this where I put the car details and a bit about myself ?........ |
Apologies, the auto-connect must have been my previous phone. The S3 just works.... I'm using it most days without problems. 2012 5.0L S/C
I have just deleted the pairing, and re-connected...but still asks for code each time I get in the car....
That's strange. I suppose it's possible the previous owner of mine got the BT module fixed (I bought it in 2010) but I know he was not technical and there was nothing in the service record to suggest the dealer did it. Maybe Wiggs is the best way after all but good luck either way! All the best... 2012 5.0L S/C
Its a simple job to do - anyone who can use a screwdriver is capable of doing this mod.
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Buy an IPhone sorted |
http://www.fullfatrr.com/forum/topic21078....th+problem
I have an S3 and have had no issues whatsoever with my S3 connecting to the car. I do have the updated module from Wiggs though as the original module was fooked. MY 2010 5.0 SC Galway green and sand interior!!
