Home > Technical (L322) > Intermittent battery problem |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
How old is the battery ?
19th Dec 2013 8:11pm |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 383 |
Forgot to include year, sorry. Its a 2011 and still under warranty. Mike |
19th Dec 2013 8:16pm |
Sorry - you did include & I missed it
19th Dec 2013 8:23pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Check the terminals to the battery and also from the battery to the starter motor, and the earth strap from the engine to the body. Make sure you have good connections for all of these. Sure sounds like something is a bit loose....
19th Dec 2013 11:42pm |
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 |
Hi Mike, can you supply a bit more info.
20th Dec 2013 3:38am |
Yes, thank you. I drive it every day but we live in a small town in the mountains (3,600 people) so I have driven it 2,200 miles in 5 months. Tonight it would not start again and the light came on the dash , the green mountain light with "Lo" on it. I waited about 15 seconds and it started and briefly the "Gearbox fault" light came on then went away and I drove it no problems. It just started last week and as I mentioned, the battery seems to be fine, cranks over fast and starts right up. Mike |
20th Dec 2013 6:08am |
Hi again Mike and with that low mileage and I suspect it’s lots of short trips, you could probably do yourself a big favour and get a SMALL multi stage battery charger and use it whenever possible.
20th Dec 2013 6:54am |
Turned out to be a dead battery which was just replaced but boy its a bear getting the old battery out!! Thanks for all your posts!! Mike |
24th Dec 2013 1:03am |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
Mike, too late now... But out of interest, did you put the 'hood' in "service mode"?
24th Dec 2013 8:17am |
Stuart Member Since: 06 Feb 2011 Location: Cambridge Posts: 85 |
Sorry, only just spotted this thread.
24th Dec 2013 4:11pm |
E 4 Guy. no we did not put the hood in service mode. The battery has to be lifted from the right side (if you are facing front) and then lifts up and out. It is very tight and we cracked some of the plastic moulding just above it to the back. The guys at my auto parts store pulled it out and the new one popped right in. Mike |
24th Dec 2013 11:12pm |
For future reference
25th Dec 2013 11:00am |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
I'm having this at the moment.
29th Dec 2013 2:36pm |
