Home > In Car Electronics (L322) > sat nav urgrade disc |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 456 |
when I've popped mine out before now I noticed it has the year on it. Perhaps yours may |
17th Dec 2013 2:58pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Yes you may change the country. But it defaults back to France, and for £3.99 i expected better |
17th Dec 2013 3:44pm |
zetjester Member Since: 01 Apr 2013 Location: Northamptonshire Posts: 48 |
I can only get the original LR discs to work in mine, and was told by an Indy DVD repair/recon company that the copies
17th Dec 2013 11:33pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
DVD's break lasers? Er....<cough>
17th Dec 2013 11:59pm |
I have tried a few copies and only the original disc will read!
18th Dec 2013 12:06am |
Yep - slowest speed possible and good quality backup discs
18th Dec 2013 12:14am |
Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126 |
Hi guys I'm new to this RR scene and was wondering will a newer map DVD work in my 2005 RR, also where is the best place to locate said item.
21st Dec 2013 1:15pm |
tobylo Member Since: 26 Jul 2012 Location: Dublin Posts: 52 |
@ Paul_H, i have 2 original discs, 2005 and 2007/2008 that i no longer need. Send me a PM and i'll send you on the details. They work in the Denso units, if you have a touch screen sat nag they will work. |
22nd Dec 2013 3:15pm |
Sat nag !!! So true |
22nd Dec 2013 3:16pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Surely these are from the same supplier as the RR puddle lights Is this where I put the car details and a bit about myself ?........ |
22nd Dec 2013 3:26pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Here in Australia if you need a new disc you are screwed The map discs are produced by a set up called Where is and now that all Land rover sat nav's are HDD apart from the Freelander2 Land Rover Australia who do not do customer service at all will not authorise discs to be made :bulb:
23rd Dec 2013 2:39am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
and is right. The newest discs we can get is the "2011-2012". Considering what they charge for the sat nav, the fact they won't issue update discs is COMPLETELY UNACCEPTABLE!
23rd Dec 2013 4:05am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
It won't make any difference. If you still have CD navigation you won't find newer maps than 2003. |
23rd Dec 2013 8:46am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
pm sent David.. ... - .- -.
23rd Dec 2013 8:55am |
