![]() | Home > Technical (L322) > Gearbox Help needed |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2275 ![]() ![]() ![]() |
Hope they fixed it for you |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1360 ![]() ![]() |
How does it perform if left in manual mode?? |
Av_dave Member Since: 31 Dec 2012 Location: Stourbridge West Midlands Posts: 109 ![]() ![]() ![]() |
The strange thing is it seems fine in manual mode. It only plays up in auto between gears 3-4 there a fault stored in it saying shift problem gear 3-4 as well I've tried clearing this but it doesn't help.
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1260 ![]() ![]() ![]() |
Have you thought of contacting RRPhil? |
Is this something he can fix? I suppose it's just the logistics of getting the gearbox up to him. The difference between theory and reality is that in theory it will work. |
He might be able to point you in the right direction to reset the adaptations. |
I've pm'ed RRPhil in the hope he may know where the problem lies or confirm it needs a recon gearbox. I have spoke to another member who has pointed me in the direction of it could be a mechatronics unit fault.
This is crazy, have the LR garage confirmed it is a mechanical fault as opposed to a software one? If not mechanical then it must be fixable somehow?
I'd use it in manual for while and see if it eventually 'learns' how to behave or until such time as I want to get more info. about more economiacl fixes.
I've spoken to RRPhil and he has been more than helpful hopefully it's a shift solenoid between gears 3-4. The problem is not many garages will strip the box down they just want to replace the gearbox as one.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
I don't agree with the notion that when the adaptions are reset that the box goes back to 0000 miles mentality.
Glynn Member Since: 20 Sep 2013 Location: Lancs Posts: 64 ![]() ![]() ![]() |
Give Grant a ring at Preston Automatic Transmissions 01772 259068
I think guys I'm going to get gearbox man to sort it. I was intrested in having a go myself but the more I learn this May end up costing more money as a specialist will hopefully be able to put his hand on the problem straight away.
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
It's very sobering to see that innocent use of a diagnostics tool can put you in this nightmare position.
