Home > Technical (L322) > Gearbox Help needed
Page 2 of 4 <1234>
Sandyt
Hope they fixed it for you
Post #230348 20th Dec 2013 7:23am
Av_dave
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Sadly not, I'm in the process now of trying to get a decent chap to fit me a recon box. Just asking round for prices at the moment and when they can do it. If you guys can recommend anyone in the West Midlands area?
Thanks The difference between theory and reality is that in theory it will work.
Post #230361 20th Dec 2013 8:40am
dingg1
How does it perform if left in manual mode??
Post #230365 20th Dec 2013 9:00am
Av_dave
The strange thing is it seems fine in manual mode. It only plays up in auto between gears 3-4 there a fault stored in it saying shift problem gear 3-4 as well I've tried clearing this but it doesn't help.
Post #230366 20th Dec 2013 9:04am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Have you thought of contacting RRPhil?
Post #230374 20th Dec 2013 9:34am
Av_dave
Is this something he can fix? I suppose it's just the logistics of getting the gearbox up to him. The difference between theory and reality is that in theory it will work.
Post #230382 20th Dec 2013 10:17am
PaulTyrer
He might be able to point you in the right direction to reset the adaptations.
Post #230387 20th Dec 2013 10:40am
Av_dave
I've pm'ed RRPhil in the hope he may know where the problem lies or confirm it needs a recon gearbox. I have spoke to another member who has pointed me in the direction of it could be a mechatronics unit fault.
Thanks for all your input The difference between theory and reality is that in theory it will work.
Post #230396 20th Dec 2013 11:12am
This is crazy, have the LR garage confirmed it is a mechanical fault as opposed to a software one? If not mechanical then it must be fixable somehow?
Is it worth seeing if your box can relearn over time, got to be better than shelling out for a recon box? - nothing to lose?
I had a similar sort of problem on my Audi, took a couple of goes but by replacing the ECU that lived inside the gearbox sorted it out. (£400 ish plus oil change) .
Post #230397 20th Dec 2013 11:12am
dingg1
I'd use it in manual for while and see if it eventually 'learns' how to behave or until such time as I want to get more info. about more economiacl fixes.
I would not be throwing money at it just yet if it was working okay before you reset it - there must be some way to reflash with software that will sort the issue out.
Post #230404 20th Dec 2013 11:38am
Av_dave
I've spoken to RRPhil and he has been more than helpful hopefully it's a shift solenoid between gears 3-4. The problem is not many garages will strip the box down they just want to replace the gearbox as one.
Will keep you guys updated. The difference between theory and reality is that in theory it will work.
Post #230509 20th Dec 2013 7:34pm
I don't agree with the notion that when the adaptions are reset that the box goes back to 0000 miles mentality.
A common issue with these boxes is the harsh downshift shunting, known as LOT (Lift off throttle). Land Rover have issues LTB's about it, and there was one for mine, which I alerted my dealer to, as I was experiencing lumpy downshifts that I thought should have been smoother.
They re-flashed the gearbox ECU according to the LTB in question as it stated that the gearbox comes with a map that is suited to semi sand driving - I presume this is because most Supercharged cars head for the Gulf region, not the UK.
After the reset it was slightly improved but still not great. Last week they reset the adaptions and it seems to be MUCH smoother.
Also, on older cars you can always do a fluid and filter flush, or a Megaflush. Lots of divided opinion on here about if this is wise or not, some feel it causes issues, I had it done on my TVD8 at about 82K and it improved the smoothness of gearchanges, and is preventative maintenance at the same time. Land Rover states the ZF box is sealed for life but tells the Dealers to do a fluid change at 100K or 10yrs, but oddly the same box in a Jag is done at 60K. Go figure. Discovery 4 HSE
Post #230522 20th Dec 2013 7:59pm
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Give Grant a ring at Preston Automatic Transmissions 01772 259068
He knows everything there is to know regarding this problem.
Stop wasting time taking advice that you know wont work and have it seen to, its most likely the mechatronic that needs replacing.
These idd tools are ok but a little knowlegde is dangerous esp with the zf6hp26 transmision.
Post #230551 20th Dec 2013 9:11pm
Av_dave
I think guys I'm going to get gearbox man to sort it. I was intrested in having a go myself but the more I learn this May end up costing more money as a specialist will hopefully be able to put his hand on the problem straight away.
Thanks for all your help and will keep you updated I'm guessing it's going to be after Christmas before any one will look at it now.
Dave The difference between theory and reality is that in theory it will work.
Post #230786 22nd Dec 2013 11:28am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
It's very sobering to see that innocent use of a diagnostics tool can put you in this nightmare position.
I was going to invest in diagnostics in the new year but this has put me right off.
What a heart sinking learning experience. I really feel for you and hope you get sorted ok. 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #230923 22nd Dec 2013 9:34pm
Page 2 of 4 <1234>
